Question about Panasonic Palmcam PV-DC1080 Digital Camera
How does the LCD work in the sunlight?
Since the cameras do not have an optical viewfinder, how does the LCD work in the sunlight?
    Master:
  • 903 Answers
The 2.5" LCD on both cameras uses a special back lighting system to help cut down on sun glare.
Posted on Sep 01, 2005
SOURCE:
Picture in viewfinder is green and white
The display being distorted can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
http://www.youtube.com/watch?v=aB4x7F5Chow
Sep 29, 2011 | Nikon COOLPIX P90 Digital Camera
I have a canon ds6031 eos 10d. When I turn the camera on the view screen does not show what your pointing at. Is this normal?
Yes, it is normal. This is a reasonably old DSLR, and it's designed for you to look through the viewfinder (it's more accurate anyway as it's looking through the lens). You'll find if you keep one hand under the lens and one hand on the shutter, it'll feel quite comfortable to look through the viewfinder.
You can still view photos you've taken after you've taken them though.
Aug 31, 2009 | Canon EOS 10D 35mm SLR Camera
Lcd problem!!!
The problem is the sensor thats right below the viewfinder. The sensor is made to turn the lcd off when you put your eye up to it . The sunlight is activating the sensor try shading it and it will be fine.
Mar 04, 2009 | Nikon D60 Digital Camera
Sony DSC-V1 optical viewfinder has a horizontal line in it
It shouldn't be there, but as the optical viewfinder is completely separate from the photographic light path it's nothing to worry about either.
Normally it's caused by either a hair or fibre which has somehow entered the viewfinder (rare) or more commonly by a fine scratch across the front window to the viewfinder. Also check the rear viewfinder viewing lens as the same damage could occur there but as that lens is relatively protected it's unlikely.
Any further fixing involves dismantling the DSC-V1 and possibly sourcing spares made of purest unobtanium so if the camera works perfectly well then leave the screwdrivers safely in the toolbox for now.
Feb 21, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Optical viewfinder zoom isn't working
no ideas on how you can get it working. There is I should think a connection adrift. Try the Konica Tech Support Team But be prepared for a zilch answer- I don't think a 'repair' will come into the equation
Jul 03, 2007 | Konica Minolta DiMAGE G400 Digital Camera
Oudoors with my Mavica....help!!!!
While it is no help for those with other cameras, Sony has fixed the problem with the FD91 which has a viewfinder that is not bothered by sunlight. The F505 LCD evidently works good in sunlight.
Sep 08, 2005 | Sony Mavica MVC-CD300 Digital Camera
LCD in the sunlight
Sep 04, 2005 | Panasonic Palmcam PV-SD5000 Digital Camera
LCD in the sunlight
Sep 04, 2005 | Panasonic Palmcam PV-SD4090 Digital Camera
LCD working in the sunlight
Sep 01, 2005 | Panasonic Palmcam PV-DC2090 Digital Camera
Panasonic Palmcam PV-DC1080 Digital Camera Logo
35 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
