Question about Coby MPC895 MP3 Player
The Safely Remove Hardware dialog box does not appear
I just got the Coby mp3 player and when I connect it to my computer the "Safely Remove Hardware" box never appears.
Even though I can find the Coby player in the computer and I can drag mp3 files to it (and the player is working normally), I'm worried that nothing happens when I connect it or disconnect it. No symbol appears!
I already checked and there´s no sign of the player in the Safely remove hardware box, as though the device were not recognised.
I have connected it to other computers and the same thing happens. With my old mp3 player I just connected it and the dialog box simply popped up.
What should I do? Is it dangerous for my computer or mp3 to be using it this way?
Thank you very much!
  • 1 more comment
  • aberaber Aug 28, 2008
    Thanks for the reply, the mp3 is working fine on my computer although the safely remove hardware box is not showing.
    But I connected it to a different computer today and the Coby icon is not showing and I am not able to open it, not even play files. What could be causing this, if it works fine on my computer?
    Thanks again!
  • aberaber Aug 30, 2008
    Just in case someone else has the problems: If you go to Settings- Usb type: Choose "Msc". If you select that option the mp3 will open the Remove Hardware dialog box and the mp3 will be working fine.
    Just in case someone else has this problem, I found out sth. Go to Settings- Usb type- choose Msc. The Remove Hardware dialog box will finally appear and the mp3 will be working fine.
    President:
  • 2,961 Answers
Not really, you may be able to select the option, if you right click on the drive in my computer, but they don't always disconnect the hardware anyway, so just remove it as lons as you know there is no activty
Posted on Aug 24, 2008
How to unfreeze coby mp600
Hello
Download the firmware update and save it to a location on your hard drive that you will be able to remember. This firmware includes a specific fix for the multiple reasons that the device is freezing.
Press and hold the "Menu" button on the player, then connect the Coby to your computer's USB port. The power on the MP3 player must be turned off when completing this step. If your MP3 is frozen, unable to be powered down, use the push pin to push the "Reset" button on the bottom of the device.
Let go of the "Menu" button on the player once the "Found New Hardware" screen appears. When asked if Windows can connect to Windows Update to perform a search for the necessary software, click "Yes, this time only," then click the "Next" button.
Choose "Install from a list or specific location(advanced)" to determine where Windows should look for the driver files, then click on the "Next" button.
Place a check mark in the box labeled "Include this location in the search," then click "Browse." You can search for the directory location where you saved the driver file in Step 1. Double-click the driver package and select the "usb_driver" sub folder as the driver location. Click "OK," then "Next."
Select the "m3usb" file from the "usb_driver" folder when prompted on the next screen, then click "Open" and "OK." The "Completing New Found Hardware" screen will appear once the drivers have been successfully installed, then press "Finish."
Unplug the Coby MP3 player from your computer.
Double-click the "USB tool" EXE that is located in the "MP3 Firmware Update" folder that you downloaded in Step 1. The USB Tool application's welcome screen appears on your computer.
Press the "Menu" button on the Coby MP3, holding it down as you reconnect it to your computer. Your MP3 is now identified as "Device 0" within the USB Tool, and you have a yellow-colored status box when connected.
Click "Burn NAND" to begin the firmware correction process. After about four or five minutes, you receive a notification saying, "Burn Task Completed."
Disconnect the MP3 player from your computer, and wait for the device to power up completely.
Click the next series of green boxes that have red lines going through them on the screen with your finger or a stylus until the menu appears. You see them in the top-right and lower-left corners of the MP3's screen as calibration on the device is being completed. The firmware is now installed.
Sep 29, 2011 | Coby MP-610 MP3 Player
I have a Coby MP620. It says to drag and drop files to the music.dir folder but I have no such folder. I have the movie, photo and text files but no music. I have no idea what to do next.
When your MP3 Player is connected to a computer, you may transfer music files to your MP3 player using your operating system's basic file management commands (i.e., copy-and-paste or drag-and-drop).Connect the Coby MP3 player to your computer through its USB adapter. Select "Open folder to view files" from the new device dialog box that pops up. If the new device dialog does not appear upon the hardware's connection, click "Start," click "My Computer" and right-click the Coby MP3 player's device icon in Windows Explorer .Click "Start," click "My Music" and open the folder containing the music you wish to transfer onto the Coby MP3 player. Drag and drop the music files or folders into the Coby MP3 player's open directory. Alternatively, you can highlight the music files or folders and click the "Copy the selected" link from the Files and Folders Tasks menu in the left column. Select the "Removable Disk" drive from the list of destinations.
Sep 16, 2011 | Coby MP620 MP3 Player
How do I delete songs
  • 1.Turn on your computer. Connect your Samsung MP3 player to your PC via the USB cord. Power on your Samsung MP3 Player.2Wait for the popup screen and select "Open Folder to View Files." If no screen appears, navigate to my computer and double-click the Samsung player.3Select the MP3 files you no longer want on your player by highlighting them with the mouse.4Right-click and select "Delete."5Close the folder and safely remove the MP3 player by using the "Safely Remove Hardware" feature in the system tray.
  • Apr 16, 2011 | Samsung Audio Players & Recorders
    Cannot down load pictures to frame from computer
    The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
    Power ON the frame.
    Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
    Connect the larger end of the USB cable to the USB port on your computer.
    You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
    The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
    To disconnect the Digital Photo Frame from your computer:
    In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
    The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
    On the next dialog box, click "OK" to remove the storage device.
    On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
    Now you should be able to see the pictures on the digital photo frame.
    Thanks.
    Mar 13, 2011 | Coby DP-772 Digital Picture Frame
    How can I delete songs from my Samsung YP-U3 MP3 Player?
  • 1 Turn on your computer. Connect your Samsung MP2 Player to your PC via the USB cord. Power on your Samsung MP3 Player.
  • 2 Wait for the popup screen and select "Open Folder to View Files." If no screen appears, navigate to my computer and double-click the Samsung player.
  • 3 Select the MP3 files you no longer want on your player by highlighting them with the mouse.
  • 4 Right-click and select "Delete."
  • 5 Close the folder and safely remove the MP3 player by using the "Safely Remove Hardware" feature in the system tray.
  • Mar 02, 2011 | Samsung YP-U3 MP3 Player
    How do you download songs from computer's music files? I copied and pasted from my library,they appear on the player when connected t computer but are not there when disconnected?
    Transfers onto he MP815 can be done through exploring 'My Computer':
    Music files must be copied into the Media folder of the player.
    In this mode, the player shows as a removable disk in the computer folders.
    Before disconnecting the player, always go through the safely remove hardware icon in the right corner below on the computer's screen.
    When you're using a software program (e.g. Coby Media Manager or Windows Media Player) for transfers, use the help function in the software.
    For Windows Media Player 11:
    0. The player should be detected when you connect the USB cable.
    1. Setup a library in WMP 11 [ Add to Library ], so the player knows the location of your music files.
    2. Create playlist: put songs in a list
    3. Sync the list onto the player
    4. Wait until synchronizing has finished
    Do not disconnect while sync is busy: a message appears when you're allowed to disconnect.
    May 22, 2010 | Coby MP815 Digital Media Player
    I WONT TURN ON
    Sometimes unplugging your MP3 player will disrupt it's file system if 'Safely Remove Hardware' or 'Eject' is not used. Following these instructions for fixing your Coby Mp-610 MP3 Player will fix your MP3 players file system.
    Feb 06, 2010 | Coby MP-610 MP3 Player
    How do i delete songs from my samsung yp-u3 mp3 player
    Greetings, Step 1 Turn on your computer. Connect your Samsung MP3 player to your PC via the USB cord. Power on your Samsung MP3 Player.
    Step 2
  • Wait for the popup screen and select "Open Folder to View Files." If no screen appears, navigate to my computer and double-click the Samsung player.
  • Step 3 Select the MP3 files you no longer want on your player by highlighting them with the mouse.
  • Step 4 Right-click and select "Delete."
  • Step 5 Close the folder and safely remove the MP3 player by using the "Safely Remove Hardware" feature in the system tray.
  • Sep 26, 2009 | Samsung YP-U3 MP3 Player
    Uploading problem
    If you have got a usb cable insert it in your mp3 player and the usb port of your computer.
    In My Computer a new removable disk icon appears.
    Open the drive and paste the song files and directories in the disk.
    Now click Safely remove hardware button in the taskbar.choose Safely remove hardware and the computer shows safe to remove hardware.take out the usb cable from both the ends.Switch on the player and listen to your songs.
    Nov 12, 2008 | Philips GOGEAR SA6045 MP3 Player
    Download mp3 music
    Power ON the frame.
    Now you can play.
    Good Luck.
    Live, Love, Laugh.
    May 12, 2008 | Audio Players & Recorders
    Coby MPC895 MP3 Player Logo
    367 people viewed this question
    Top Coby Audio Players & Recorders Experts
    Gyula Lacz
    Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
