Question about Panasonic KX-TG2383 Corded Phone
Key Pad buttons require more force to accept the input - loosing memory!
Hi, If I could, I would buy this model again but alsa, no one seems to offer this phone any more. My key pads on the cordless phone are loosing the memory - mechanically - I have to press harder now and sometimes two to three times before the entred key is accepted. can this key pad be replaced ?
I have the same phone with the same problem and didn't want to part with it either. The cause of the problem are skin oils that seep down the rubber keys, and through slots at the base of the molded pad, thereby interfering with electrical contact. There is a vendor on ebay that sells a tape like pad with larger contacts that solves the problem perfectly. Go to ebay and use the following search term (I know this isn't the same model number, but its apparently compatible) :
Panasonic KX-TGA230 KX-TGA270 KX-TGA230B BUTTON FIX
The price is 5.95 including shipping. The repair pad will come with an instruction sheet, or you can go to the website on the instruction sheet and download about a 40Meg video file that shows you exactly how to make the repair. My phone operates with a nice light touch now that its fixed. Good luck.
Posted on Feb 07, 2009
I have just change the batterys on my sandleford electronic safe ES23. now I can not put my same code back in. can u help me please. it has a key n a key pad as well.
Open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code, then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Jun 27, 2016 | Locks & Locksmithing
Hi I have just tried to set up my son's ocean netbook. I seem to have locked the keyboard somehow!! Any assistance would be greatly appreciated.
Locked as in it doesn't accept input? Some laptops will have physical buttons on them for disabling the touchpad and keyboard. Please list the make and model if you need further help.
Thanks
Jan 26, 2013 | Computers & Internet
Cursor problems
Boot up in Safe Mode and see if you can use the touchpad. It might have been hijacked by a virus or infection.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If the cursor and touch pad seems to be ok open your internet browser to download and install MalwareBytes and run a Quick Scan.
Go to www.google.com and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
Click Start/Control Panel and look for the Mouse and open it to check the mouse properties. Make sure you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and Hold the ALT or FN function key located at the lower left portion of the keyboard, then hit the key that toggles the touchpad. The correct key to hit will have the icon of a finger pointing at a square that represents the touchpad.
Download and reinstall the touch pad drivers.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers.
Jun 02, 2012 | Computers & Internet
Hi. The flash seems to have stopped working. I have tried all sorts of buttons and now I have icons showing on the screen that weren't showing before. Can I just reset the camera back to when I bought...
You Need to replace the Flash Tube. Thats may cutoff. but before that try these.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 01, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Sep 04, 2009 | Dell Inspiron XPS M140 Notebook
Reebok Vista Treadmill issue
Have a 2 year old Reebok treadmill. Control panel was replaced right after we bought it. Now, again, the upper half of the panel works but we are not allowed to start anything. Does the whole panel need to be replaced again or is there a fuse or something small that we can do.
Jun 07, 2009 | Reebok Vista Treadmill - RBTL13305
NO SOUND ON A NEW HP DV4
the best resolution for this issue is
go to the device manager and uninstall the sound drivers and than restart the system and the drivers will get detected again and the issue will be resolved
Dec 24, 2008 | HP Pavilion dv4000 Notebook
Service required....canon mp 180
This worked for me:
  1. Turn off the printer ( "Power" button).
  2. Hold the button "Resume" (red triangle in a circle), click and hold "Power" - an indicator light green.
  3. While holding the "Power" button, release the button "Resume".
  4. Not releasing the "Power" button, double click "Resume" and release both buttons.
  5. Four times click "Resume"
  6. Once you click "Power", to confirm the selected action (reset counter absorber). Click "Power" again to turn the printer off and once again to turn it on.
Dec 18, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Kenwood receiver
I am a little hesitant to offer this help, but you should not pay for others inconsiderate actions. It seems that whenever I tell somebody how to do this procedure, if they have no remote, they get mad and give me a bad rating. You must have the remote for this procedure. And yes, it will work, and no, there is no other way to clear the code. This seems to make people mad. Sometimes they don't believe me. But I do work at an authorized Kenwood repair center and know these things for certain. I will give you this procedure, and if I get another bad rating for giving out this free help that Kenwood doesn't want us to tell anybody, then I will have learned my lesson and never offer this help to anybody again.
Here are the directions right form the service manual for your model.
How to clear the programmable security code (For models
of destination “K”)
∗ Operation 1
1. While “– – – –” is being displayed, press [>>I ] key for 3
seconds or longer while pressing the [AUTO] key on the radio. This
makes the “– – – –” display disappear.
2. Input “KCAR”, using the remote controller.
Press [5] key of the remote controller twice (Input for “K”)
and press [ >>I ] key.
Press [2] key of the remote controller 3 times (Input for
“C”) and press [ >>I ] key.
Press [2] key of the remote controller once (Input for “A”)
Press [7] key of the remote controller twice (Input for “R”)
3. The security is cleared and the unit enters STANDBY
source.
4. If wrong codes are input, “– – – –” will be displayed again.
If you really do not want to buy another remote, see if you can borrow one from a friend, it doesn't need to be from the same model, just make sure it is from a Kenwood car stereo.
If you can not borrow one from a friend, you can take it to an authorized service center for Kenwood and they will do it usually for a small fee. My shop charges $25, I can not say what another shop will charge but my guess is that it would be similar.
I hope you have found this helpful, I am happy to help you further if you need any more help.
By the way, the only good rating is a FixYa!.....all the other ratings just hurt my overall average.
Dave
Nov 27, 2008 | Car Audio & Video
Won't accept key input
There might be a problem in ur.....key pad. Did u tried to install the previous battery.......again.....
Jul 14, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Panasonic KX-TG2383 Corded Phone Logo
166 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
