Get your water tested.
Here is what you must do when you fill your pool ... 1st, get the metal out. Use a sequestering agent, follow the bottle instructions exactly. 2nd, get the alkalinity proper (goal is 100) 3rd, get the pH proper (the goal is 7.4). 4th, introduce your salt (should be about 3200 ppm) Check the balance using the Taylor Water Balance Wheel. Getting your water correct may take several days.
Another thing you should consider is using cyanuric acid (aka stabilizer). Cyanuric acid acts like sun screen for your chlorine. The sun will eat your chlorine almost as fast as you make it if you dont use Cyanuric Acid.
I hope this helps you out ... you can get additional free advice from your professional pool supply store. Stay away from the discount place for best results.
Thanks for your interest in FixYa.com
