Question about Technics SL-1200MK2 Turntable
Volume I am a noob when it comes to turntables. I inherited an sl 1200mk2. I can not figuire out how to get the volume to play louder. I have a very nice sound system but can not get to play at high volume
  • 515 Answers
As LOCAUSS stated, you have to connect to the following:
1) Turntable --> PHONO (input)
or if you do not have a PHONO input, then you have to buy a PHONO PRE-AMP, from there...
1) Turntable --> Input on Pre-Amp --> Output from Pre-amp goes to INPUT of either Line, CD, Aux, or Tape input on receiver/amp/system.
Hope this helps.
- OPTiC
The 1200s Expert
www.1200s.com
Posted on Sep 08, 2008
  • 3 Answers
I has the same problem. You must plug it in into your PHONO receiver. If you do not have a PHONO line in, you have to buy a Phono PreAmp at Guitar Center and once you set it up, you can then plug it into any input. Good Luck
Posted on Sep 01, 2008
    Problem Solver:
  • 7 Answers
Please let me know how your turntable is connected to the music system. I mean, to which input ? (Tape/Aux/Phono/VCR/CD) ?
Posted on Aug 25, 2008
Technics 1200 mk3 distortion
nice table, but i need to know more info: distortion with only the record playing or also a sound with the unit only on, which cables do you use and did you have cleaned the rca cable and the sme connector(those 4 pins where you screw your om or concorde in) with cotton on a stick and the right cleaning stuff and push them a couples of times , to see if they come back easily, other wise a drip of lubricator for elektronics on them . greetings richard
Jan 10, 2014 | Technics SL-1200MK2 Turntable
Im playing my SL-1200MK2 threw serato and it when i press play to make the record spin serato pick up that the record is slowly spinning backwards? and no noise is coming from the record
do you have your timecodes set properly and configured with serato? that could be the issue try adjusting the timecodes w serato and basically re sync them. if this doesnt help please let me know
May 11, 2011 | Technics SL-1200MK2 Turntable
One channel on my sl1200 mk 2 has very minimal sound out put. I have to turn my balance selector on my reciever almost full right to balance the volume. Any insight to this problem is...
As a test, switch the right and left RCA cables from the turntable to the amp. If the problem reverses, the issue is in the turntable or with the cables. If it stays the same, its a problem with the amp.
Nov 16, 2010 | Technics SL-1200MK2 Turntable
Just bought a new Shure high performance stylus for my Technics SL-1200MK2. After a few weeks of use, while a record is playing the volume on the left channel will drop significantly. If I take the...
it could be two things:
1.the tone arm wires that connect to the head shell (blue-red-green-white i think)
2. the needle arm has twisted round
Put it on the other deck if you've got one & see if it does it.
look right at the end of the needle tip,& see if it's straight & pointing down, if not carefully twist the needle arm round until it is,& push it into back in to the cartridge a little bit.
Sep 30, 2010 | Technics SL-1200MK2 Turntable
I have sl-1200mk2, and the signal does not come in
The first thing to is try to eliminate the cartridge as a cause of the fault. You can do this by swapping the connections around on the cartridge. If you get the weakness still on the Red cable you know it is that. Solder joints do cause trouble, often the earth is the problem. Try resoldering the joints. Or replace the entire cable as there might be a break.
May 14, 2010 | Technics SL-1200MK2 Turntable
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
252 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
