Sad to say, that clicking sound is a common sign of a bad hard drive. A working system might be able to read data from the drive if it retries enough times. You can remove the drive from the laptop and connect it to another computer using a drive adapter or by putting it into an external drive case. The clicking sound usually means the drive is pretty far gone, though. Hopefully you've been backing up anything important.
I wish I had more positive news.
The hard-disk password (HDP) protects the data on your removable hard disk drive from being accessed by unauthorized persons.
Supervisor Password
The supervisor password protects the system information in Easy-Setup from being changed by unauthorized persons.
How to Reset an IBM ThinkPad Power On Password using Software
If you can boot the IBM ThinkPad, KeyMaker will recover the BIOS password.
How to Reset an IBM ThinkPad Power On Password Using Hardware
If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
