THis is from the HP tech chat thing, and it seems to be working. I did method 2 and browsed to the file: _________________ 1. Click Start 2. Click Shutdown 3. The "Shut Down Windows" dialog box will be displayed 4. Select "Shut Down" from the me 5. Start the system again. 6. When the Red Compaq logo appears press F8 repeatedly until prompted with the "Windows Startup Menu" 7. Select option 6 (Safemode Command Prompt) by pressing the down arrow key until Safe Mode Command Prompt is highlighted 8. Press Enter 9. At the C:\ prompt type D: and press Enter 10.At the D:\ prompt type CD CPQS and press Enter 11.At the D:\CPQS prompt type XQR press Enter Method 2: 1. Click Start 2. Click Run 3. In the "Open" box type C:\CPQS\QUICKSR\FRESTORE.EXE Performing these steps should resolve this issue.
Once try to Re-Install your Operating System and Just after Installing your OS just once Mo niter your CPU usage in Task Manager if it is Simply raising to 80% to 100% then it is a issue of over heating
if you can view your desktop and use the menus, go to start/all programs/accessories/system tools/system restore, if you had enabled this option earlier then you can restore the system to an earlier known date when you system worked.
else you can try installing winXP again, try the option to "Update" when the install option comes on.
else start PC, before the WinXp screen comes on press F8 key, use the Safe Mode to start PC, if you can see everything then shut down and restart in normal mode.
Visit driversguide.com, register yourself(its free) and finally visit this link: http://members.driverguide.com/index.php?action=dosearch&qm0=Compaq+Presario+5000+PC&qa5=1&qa6=236&qa7=All+Windows&dp=3&sm=h&jmd=and&fzz=d&si=0714a172c4fc2aef5b5a2106375cb1db&st=1240205618&gqm0=Compaq+Presario+5000+PC+BIOS+Motherboard and get your drivers.......sodeep
