Question about Optoma HD72 Multimedia Projector
HDMI Port quit working
I have an Optoma HD72 and the HDMI port quit working, component input still works.
  • 4 more comments
  • wdixon Aug 24, 2008
    I only have about 500 hrs on the Projector.
  • bdickinson33 Aug 28, 2008
    I have the same problem on in reverse. The HDMI port works fine, but the component port stopped working suddenly.
  • Anonymous Sep 25, 2008
    I have the same problem. HDMI is not working now. All others good.
  • Anonymous Oct 13, 2008
    The same problem for 3 month projector.
    Any solution ????
  • LegendaryJ Jan 26, 2009
    My HDMI port is not detecting my Xbox 360. I have the same problem. I tried cleaning mainboard and port with canned air and still nothing
  • Anonymous Mar 18, 2014
    I have Optoma HD230x, and the 2 HDMi ports are fried. So need to replace the HDMI port, could you please tell me the name of the part or an alternative to make HDMI ports to start working
  • 431 Answers
My first guess is to inspect the lead try the easiest solution first then approach the difficult after .
The second course is more painful if the lead is indeed ok then you are probably looking at one of three things constant plugging in and pulling out has caused microfractures on the pcb circuit isolating the HDMI plug ,Or dry joints on pcb , And failiure of input components on circuit . Sorry not to be the bearer of better tidings but this is one of those faults that make an engineer scream ?
WITH JOY £££$$$$££££ as it is going to take ages to find ?... Regards Vortash
Unless it is a common fault and is described in the engineers service notes lol.
Posted on May 10, 2009
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Aug 11, 2011 | Optoma HD20 DLP Projector
Hi i want to connect a tv to my optoma hd 66 projector
hi,
You can't be able to connect a tv to your projector, because it doesn't have a monitor out.
There is only one way. If the source is a DVD player then connect the its HDMI output to the projector and the component video out to the tv. You can't be able to get video out from the composite video output of your DVD player, when you are using HDMI. When plug the HDMI it will switch off the composite video out. The component video out remain ON whether you connect HDMI or not.
ok
Mar 31, 2011 | Optoma HD72 Multimedia Projector
I just got a new Optoma HD20 and only after 1day of use it is not showing HDMI signal, although it is showing VGA signal. Why is this?
Hi miracles4all: I solved HDMI signal issue in my Optoma HD20. In my case it was the lack of contact between the HDMI cable plug male ending and the Optoma HD20 HDMI female port. My 35ft cable plug male HDMI ending was not completely "seating" in the Optoma HD20 HDMI female port. I solved the problem by purchasing a HDMI female to female coupler and adding a 3ft HDMI cable that had a slim male ending. This 3ft HDMI extension cable made better contact to the Optoma HDMI port and the projector was immediately able to detect HDMI signal. Hope this helps you... kaufmanekpr
Nov 05, 2010 | Optoma HD20 DLP Projector
I want to pair my laptop (lenovo N100) to my mobile (samsung corby tv) i could not find the pin ? please give me the steps
Does your laptop have a VGA-output port? an S-Video port? a HDMI output port? component-output port?
Does your TV have a VGA-input port? an S-Video port? a HDMI input-port? component-input ports?
Match the "output" to the "input", and you should be OK.
Jul 03, 2010 | Computers & Internet
HOW DO I CONNECT A AN EZPRO 610 PROJECTOR TO A LAPTOP COMPUTER.
1. You will need a VGA or S-video cable and a 1/4 inch stereo plug that will go from the earphone jack to the EZpro then out to a amplified system for the sound.
2. I believe the EZpro has connections for HDMI which will supply sound as well as High definition video. You should have an adapter for the HDMI also if you
3. connections port as follows:
1. USB Connector (Connect to PC for Remote Mouse function)
2. RS-232 Connector
3. Audio Input Connector
4. S-Video Input Connector
5. DVI-I Input Connector
(PC Digital (HDCP)/PC Analog/Component Video Input)
6. VGA In/SCART Connector (PC Analog Signal/Component
Video Input, HDTV/SCART Input)
7. VGA Output Connector (Monitor Loop-through Output)
8. Power Socket
9. KensingtonTM Lock Port
Looking at the usb port go counter clockwise the numbers are in succession. 1- 9
1 Power Cord
2 VGA Cable
3 DVI-I to VGA Cable (Optional accessories)
4 Audio Input Cable (Optional accessories)
5 RS232 Cable (Optional accessories)
6 USB Cable (Optional accessories
Apr 24, 2010 | CTX Optoma EzPro 610 Multimedia Projector
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Optoma HD72 flashes red and green. I changed the lamp but the problem wasn't resolved. Any input would be greatly appreciated.! Greg
I had the same problem with flashing colors after playing for awhile. The following helped:
1. turn off bright mode from menu.
2. keeping the back side of the projector flat. I had it raised up about 3" on the backside before, not sure why but it worked fine when flat.
Hope these help you also.
Apr 11, 2009 | Optoma HD72 Multimedia Projector
Sceptre X37sv-Naga 37 HDMI port is not making contact
hd EZ lock by Blue Echo Solutions is a Universal HDMI Locking Adapter, the only one on the market. It works with most HDMI Cables and components and attaches to your component's chassis, using the existing screw above or below your HDMI Input or with the supplied adhesive. It supports your HDMI Cable from the component's chassis, eliminating stress on your HDMI Input and keeping your HDMI Cable in place. www.blueechosolutions.com
Oct 17, 2008 | Sceptre X37sv-Naga 37 in. LCD Television
Short picture time when starting Optoma HD72 projector
Mine did the same thing. The bulb is used up...replace the bulb. That fixed mine, working great again.
Oct 05, 2008 | Optoma HD72 Multimedia Projector
Optoma HD72 Multimedia Projector Logo
661 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
