Question about Dacor Preference RSD30 Gas Kitchen Range
Dacor Epiente 36"Range Oven Contrrol Panel won't work.
I ahve a epiente 36" range. The control panel won't work. I try to turn on the oven and the temp setting will not set. The up and down arrows will not set the temperature. I also cannot set the timers. The up and down arrows will not work. Is it possible that the control pads can be replaced??
  • 2 more comments
  • moose1960 Aug 24, 2008
    tried and nothing changed the up down buttons still are not working
  • moose1960 Aug 25, 2008
    yes everything else works i did shut off the power but maybe not long enough the clock did not reset
  • Anonymous Oct 27, 2008
    We have had this problem a couple of times now - we were just poking around online becaue we could nto remember what to do - turning off the breaker for a couple of minutes worked, our control panel is back on ... now if only our ignition heads worked consistently....
  • abrsjnk Nov 27, 2008
    We have the same problem. We turned off the circuit breaker all night. The temperature settings still don't work, but we can get rid of the F-1 beeping and can turn on the option for setting the temperature of the convection oven. We're stuck on Thanksgiving day.
  • 725 Answers
Does the clock work? try a hard reset (turn off the circit breaker for 1 min .. then turn back on or you can also check TCO you under the grille be sure to turn the power off
Posted on Aug 24, 2008
  • Franklin Ouchida
    Franklin Ouchida Aug 25, 2008
    So the up and down button are not working but you have clock and other buttons working?
  • Franklin Ouchida
    Franklin Ouchida Aug 26, 2008
    if the clock did not reset to 12:00 then you did not do it long enought..
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
Dacor Preference range oven stoped working
You can try turning the breaker off to the unit for 10 minutes or so but if that does not work you will need a new control board to fix it. they usally range from 100-200 dollars.
Let me know if you have any other questions.
Phil
Apr 10, 2009 | Dacor Preference RSE30SS Electric Kitchen...
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
The display panel for the oven control of our Dacor Model RSD308 Duel Fuel Range suddenly stopped displaying correctly. The display panel shows parts of numbers and letters so you cn't read temperatures or...
Once the display board stops showing the numbers and functions, you have to replace it. You could try and turn the breaker off to it. Sometimes this will reset the main board unit.
Feb 26, 2009 | Dacor Preference RSD30 Gas Kitchen Range
ERD30S- oven wont turn on
Hi! jpdufilho
Try tuning off the power to the unit for 20 minutes. If this does not fix the problem you may need a new control board/panel. If you have a lot of lightning in your area you should have several surge protectors in your house. All electronic devices need some type of surge suppression.
InMrFixIt
Nov 09, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Range works, ovens do not
CALL DACOR DIRECT AND ASK FOR MICHAEL, HE IS THE SON OF THE OWNER.
Dacor 1440 Bridge Gate Drive
Diamond Bar, CA 91765 Toll free: 800-793-0093 Main: 626-799-1000 Fax: 626-403-3130
Jul 09, 2008 | Dacor Epicure ER48D Stainless Steel Gas...
ERD range oven won't heat
Dacor service said it was a control panel issue with the high limit.The cooling fan should also be set from 300 to 200
Apr 24, 2008 | Kitchen Ranges
Dacor Preference RSD30 Gas Kitchen Range Logo
336 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
