Question about Olympus D-600L Digital Camera
Color filters
Can I use color filters with the camera?
    Master:
  • 852 Answers
No, color filters will impede the AWB (Automatic White Balance) circuit which will result in improper color expectations in the final image.
Posted on Sep 01, 2005
What is the purpose of an R2 filter?
Each filter intensifies its color and darkens others, especially the color opposite on the color wheel. They're not of much use in color photography, unless you want weird color casts, but they come into their own in black&white photography.
For example, a red filter intensifies red and darkens blue. It can make a sky look almost black, making clouds pop out. Similarly it can darken foliage. A green filter on the other hand will brighten foliage.
If your camera can take black&white photos, try taking pictures of a red rose with green leaves with and without the filters. With one combination the rose and the leaves will be the same shade. With a red filter the rose will be bright against the dark leaves. With a green filter you'll get a dark rose with bright leaves.
With digital photography you can achieve the same effect in postprocessing, but some times its easier to get the result in camera.
Apr 28, 2012 | Quantaray 55mm Red R2 Lens Filter
How do i take black and white photos with the EX S880
In the recording mode, press MENU. On the "Quality" tab, select "Color Filter" and press cursor-right. Use cursor-up/down to select "B/W" and press SET.
It's in the "Using the Camera's Color Filter Effects" section of the manual (page 139 in my copy). If you need a manual, you can download one at
http://support.casio.com/pdf/001/EXS880_e.pdf
Nov 14, 2010 | Casio Exilim EX-S880 Digital Camera
Color problem
try to see if a filter is activated like magenta ...look in the menu if there is a reset settings feature...Usually it is in the main menu..one that reset it to the factory settings ..there can not be any other thing but something from the settings activated..(look for color filters) another thing to look for is if there are modes on it that change manually and can not be reset on digital level....I mean switches and stuff..or turning buttons for modes..try to put them in normal node..
May 25, 2010 | Olympus FE-280 Digital Camera
Green tint on flash photographs
without color correction software on your pc, you may get green tint from the flouresent flash, or use a "filter" over your lens.More expensive digital cams correct for this, back in the 35mm days, I had color correction filters I interchanged during shooting under other than daylight conditions,i.e., incadescent; flourescent;ect.
Jan 27, 2010 | Moultrie MFH-DGS-100 Digital Camera
Change old pics from black & white to color on a canon powershot
You have it on a filter setting that extracts color...go into the menu and scroll to filters and change the setting.
Oct 22, 2009 | Canon PowerShot SD870 IS Digital Camera
Using filters on Fuji 9500
the red filter was not for having the camera in color mode, if you try switching it to black and white, then it will darken the sky and make clouds stand out, or in color mode if you are in a room with blueish lighting, the red filter can be used to adjust for that, but that can be adjusted by changing the white balance
Apr 12, 2009 | Fuji FinePix S9500 Zoom Digital Camera
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Blue skies
Things to consider regarding "blue skys"... Time of day (Sunlight has different color spectrum mix & kelvin temp as the dawn passes on to night. Atmospheric conditions - humidity, ozone, smoke/dust - all filter the colors White Ballance - Do a manual WB before shooting each series. Camera - different sensors are not created equal. One may play more to the blue end, another towards flesh tones. Lens systems, filters affect it too. Many say a good polorizer is one of the best investments for outdoor photos Display media - Monitors need to be color balanced to accurately portray "what you shot". Likewise, color print labs do best with digital files tuned to their specific hardware profiles.
Sep 06, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Color filters
Aug 31, 2005 | Olympus D-500L Digital Camera
Filters
Yes, the Olympus E-20N has a 62mm filter thread size. You can attach a standard 62mm lens filter directly on the lens. Color filters would not have an effect on the camera due to the auto white balance.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Olympus D-600L Digital Camera Logo
23 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
