You may find this a useful site in the future:
http://www.cuisinart.ca/cuisinart_product.php?item_id=63&product_id=58&cat_id=2
Your Instruction Booklet:
http://www.cuisinart.ca/pdf/ibs/en/DCC-1200C_en.pdf
It is likely that calcified deposits are gradually breaking away as you now use the coffee maker. Is your Self Clean light flashing? Instructions on decalcification and cleaningh begin on page 5 of your booklet.
To clean, fill the water reservoir to capacity with
a mixture of 1/3 white vinegar and 2/3 water. For your problem, let the vinegar solution sit in the reservoir for 30 minutes to an hour before beginning the cleaning cycle.
Press the Self Clean button. When the self clean light glows, turn the coffeemaker on by pressing the ON button. The self clean light will shine steadily. The coffeemaker is now in Self Clean mode. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, the coffeemaker will shut off. Turn the coffeemaker ON to see if the Self Clean light continues to flash. If it does, turn it to OFF and then repeat the cleaning procedure with a fresh solution of vinegar and water.
If the Self Clean light no longer flashes, turn the coffeemaker to OFF and then run one cycle of fresh cold water through the unit before using the unit again to brew coffee.
If you continue to see debris, unfortnately you will have to repeat until clear.
