I cant get my laptop to connect wirelessly to my router
  • 3,051 Answers
If you click on the properties of the wireless that u are using and go to configure you will be able to set the chanel that you will need like my belkin is chanel 6 or 11 and my region is 49-165 the device is set to default when it is installed i had to learn this on my own but now it is pretty easy to do hope this helps you a little bit ok best regards mike
Posted on Aug 24, 2008
Cant connect to d-link DIR-615 wirelessly, can someone help me?
What is the operating system on your laptop?
Can you access the Internet if you connect the computer to the router with the Ethernet cable?
If the wired connection is working then it must be the problem with the wireless network.
If the wired connection is also not working then you may need to reset and reconfigure the router.
If only wireless is not working then you can try creating a new wireless network and then connect your laptop to the new wireless netwok.
I can suggest you a website which may help you for Home network connection.
May 20, 2012 | D-Link DIR-615 Wireless Router
My laptop quit working cant get no connections through router
First; Does your laptop see any wireless connections? If no wireless connections are showing up, your wireless card could be off. Depending what type of Computer you have, it could be a slide switch in front, if its dell, you can push Fn and F2, If you do see wireless connections, and just cant connect,. try shutting down your Computer, unplugging your Modem, and Router. Restart, then see if you can connect. Wireless has so many issues, If you still can't connect, let me know and I will give your more information. Hope this helps.
Oct 12, 2010 | Belkin (F5D7230-4) Router (587009)
Cant connect ,no light on wireless connection. was
you need to setup the wireless connection if you havent already and your router needs to be a "wireless" router in order to create that type of internet connection. Have you laptop then scan for one which would be the one you just made and input the correct information to connect. If that doesn't work I'd suggest getting a new wireless router
May 06, 2010 | Belkin F5D8236-4 Router
Laptop cant connect to internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 06, 2010 | Linksys Wireless-G Broadband Router
Our wireless net work comes up but we cant connect to it why?we have a wireless g wgr614v9 router and we cant log on to it with the passphrase
The Netgear router needs the wireless settings configured i.e SSID, WPA encryption etc and the wireless card in the laptop/computer needs to be configured with the router's wireless settings for the laptop/computer to connect with the Netgear wireless router. Pleas click on this link and follow my instructions to secure your wireless network, configure the wireless router's settings and configure the wireless card in the laptop/computer :-
Feb 21, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
My vista laptop wont connect through the router
you said it says connected to the network but not oline.
Check the IP address on the wireless network connection.
there might be nay static IP address on the wireless connection.
If yes then set to obtain IP automatically.
Click here for more information about routers
Jan 01, 2010 | Linksys Wireless-G WRT54G Router
Laptop driver needed
You dont need a driver for the wireless router. If your laptop can recieve wireless signal(from a wireless router) all you need is an active internet connection, configure the laptop and router to distribute the internet, you're good to go.
If your laptop cant recieve a wireless signal from a wireless router then you might need a USB Wifi Dongle.
Apr 06, 2009 | Linksys Wireless-G VPN router with...
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
Jun 19, 2008 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
