Question about Car Audio & Video
Pioneer DEH-P3000IB problem.
I can't find SW (subwoofer) CONTROL using the MULTI-CONTROL (volume dial) in order to change the rear RCA output from a subwoofer signal to a full range signal. It is explained on page 26 of the Operation Manual but I can't find SW CONTROL to do what I need to do. Please help
  • Anonymous Mar 13, 2009
    yea i think thats whats making my rear speakers not work
  • yanzukmjy
    yanzukmjy Mar 07, 2012
    I know this is an old post but just ran into the same problem with my brother in laws Pioneer Radio. Well, it turns out that the head unit has to be OFF before you try to change the subwoofer setting. THen press and use the Multi-Control knob to select SubControl and change this to REAR SP: FULL (this gives you full range sound) or REAR SP:SUB W (this is for only low, subwoofer frequencies). His radio was set to sub, which is dumb because it was installed with a 4 channel amp and 4 full range speakers. Not sure why it was setup like this in the first place but oh well...
Posted on Mar 07, 2012
  • 30 Answers
This is the link to Pioneer's support website, where you can download owners manuals and installation manuals.
Hope this helps.
Leadispenser
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/DIN/DEH-P3000IB?tab=D
Posted on Aug 27, 2008
I Have a 2000 Impala without onstar, i tried to replace the in-dash radio with an aftermarket one, i bought an 80$ wiring harness for my car because of a chime and it came with 4 rca cables along with the...
The four RCAs are for the speaker outputs.They plug into the rear of the Pioneer unit (front and rear outputs). Also, you didn't mention the model number of the wiring harness (necessary to properly diagnose the situation) but, some these units have one or two philips head dials to adjust the volume of the stereo and the volume of the chime. These dials may be on the side of the unit or, oyu may need to open the casing to see them.
Jan 26, 2011 | Pioneer DEH-3900MP CD Player
Need to know what connectors to buy to install my pioneer audio?
You can usually purchase a wiring harness for your vehicle to ease the connection to factory wiring. Two examples would be here:
Toyota Into Car Harness
Toyota Into Radio Harness
Feb 01, 2009 | Pioneer DEH-P3000IB Connect an iPod nano...
Connecting an ipod
Just press the bottom ipod in your player and start browse your ipod lists from your player
Jan 06, 2009 | Pioneer DEH-P3000IB Connect an iPod nano...
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
No fader control on a pioneer deh-2000mp
No fader control when using the onboard amplifer or an external one? Do you have all of the speakers hooked up correctly or are you running the fronts and rears off of two speaker outputs?
Jul 16, 2008 | Pioneer Car Audio & Video
Pioneer p3000ib reciever connected to audio speakers with no problem but dont know why the 2 rca woofer cables to amp dont work i tried with new signal cables and still a no go...The woofer and amp work...
On the right side of your display you will see a pair of buttons in the upper part of the face. These two buttons are vertical. The bottom button of those two is the SW/Bass button. Press this button and it switches the display to the subwoofer menu . Check the settings here to make sure the subwoofer output is turned on. Each time you press it, it should change menu setting. If you press and hold, it will change to the bass boost menu.
If this does not help you to turn on the subwoofer, it could be an internal problem in the radio that would need to be checked by a professional. Many of these Pioneer radios have an internal fuse that can open up. It is not the type of fuse you could change yourself. It is a surface mounted fuse that is very tiny and does not look like a fuse at all. It would require very good soldering skills to replace and knowledge of this particular component just to locate it.
If you found this free information helpful a good rating would be appreciated.
Let me know if you need any more help.
Dave
Jul 06, 2008 | Pioneer Car Audio & Video
Ipod plugged in front RCA
Please first check whether Sub Woofer works independently?
check whether SW is "on"in AUX mode.
Apr 12, 2007 | Pioneer DEH-P5800MP CD Player
RCA Problem
You need an active subwoofer input in your amplifier.Which amplifier you are using? Only latest pioneer amplifiers has active sub input and sub output which can be connected to subwoofer.If you dont have active input then you will have to connect it the way you did in old player.
Feb 10, 2007 | Pioneer DEH-1800 CD Player
Car Audio & Video Logo
381 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
