Question about Frigidaire PLEF398AC Electric Kitchen Range
Atlas La Stella double oven
We are getting huge amounts of acrid steam/smoke when using oven at high temperatures. The oven has been cleaned but problem persists! We do seem to get a build up of fats on oven base, despite care taken not to spill fats etc. HELP!!!!
  • 639 Answers
Hello Roland,
happy to help you out!
You must clean by way of wiping excess spills and materials dripped or spilled before self clean is operated. Or there will be smoke even during the self clean process!
Also do not wait till there is build up galore to self clean your oven!
If you spill or splatted and drip in the oven that day,
start the self clean after you do the dinner dishes!
More info can be found int he owners manual!
Posted on Aug 24, 2008
Why does my oven smoke when in use
If the top lifts up to clean you should check under there. Its like a drip pan and if anything got spilled on the top and went down it could be the problem.
Jun 02, 2015 | Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I just used the self cleaning option for the first time and the entire house filled with hazy smoke and a very strong , almost chemical odor - what is wrong?
The self cleaning setting goes to a very high temperature ,it is this high temperature that cleans the oven ,the remains that was left in the oven.during the cleaning cycle would have likely caused the hazy smoke and strong odour . Recomendation : use your vent fan , remove heavy residue from the oven before starting the cleaning cycle.
Dec 03, 2010 | Frigidaire Ovens
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 | Ovens
Where does the charcoal go?
please clarify your problem, i am providing only general solution, any "contraption" of that type is divided into several sections, on the very bottom is ash container, above is fire and at the very top is food compartment. food compartment is usually insulated from direc fire.
as a fire you can use any "sweet" hardwood, any fruit tree cuttings, branches, kindlings are fine, so is hickory, oak will turn food bitter, do not use it then, do not use mapple, birch or ivy either, they will turn food very sour, do not ever use grass, pine or similar, they do spoil food acrid and turn smokehouse acrid for very long time.
do not allow vigorous fire as this will raise temperature to high and you will be baking not smoking!
as a rule of thumb, per 1000g of mass is required 1h of smoking, temperature, depending on meat/product (you can smoke cheese, fruits and others!) should be between 60centigrade and 85 centigrade, lower the temperature (optimal for virtually everything is about 72 to 75 centigrade), better product and better taste, but extended time!
prepare your meat according to favourite recipy, smoke, prepare pot with boiling water, immediatelly after removal from smoke, immerse your meat (especially susages for about 10 sec into boiling water, allow to dry and store in coolroom or dry it above your "normal" cooking stove in your kitchen, it will not spoil, it will just become more dry.
now, how to care, afte smoking, empty ash and fire "department", wipe clean all working surfaces, prevent from direct rain, you can use bit of lard ot grease food compartment, but it is not necessary, experience will teach you more :-)
Jul 20, 2010 | Char-Broil Grilling
Self Cleaning Oven
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 31, 2010 | GE Profile 30" Self-Cleaning Drop-In...
Oven smokes
If it smoke smells of burnt food or grease you have something on the surface of the element which is burning off.
If it is an acrid smoke it could be the element itself is on the way out or the fan (if it is a fan oven).
You need to make a visual check of the element/fan to ascertain their condition and clean or replace as necessary.
Nov 30, 2008 | Ovens
GE monogram double oven display getting extremely hot
Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Frigidaire PLEF398AC Electric Kitchen Range Logo
230 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
