Question about Peavey Escort 2000 Microphone
Peavey Escort system
My Peavey just up and died. Plugged it in, turned it on and POP. Changed the fuse. Can't figure out what to do next.
Would you like to sell your system i need parts
wete502764@aol.com
Posted on Feb 11, 2009
My peavy escort 1500 keeps shutting off but will come back on if I turn it off and on is it a fuse?
Can't be fuses, as it comes back on!
Questions:-
i) Does it go off when run continuously with volume controls at zero?
(this checks whether the audio output level is causing a problem).
ii) When the unit does operate, is the sound good on both speakers?
iii) Does the fault occur more when outdoors (wind noise tripping the power protection). If so, reduce the low freq EQ setting.
iii) Do the EQ lights flutter when the fault occurs?
This fault has been reported on the Escort 3000 too, see link
Peavey Escort 3000 sound cutting out - Peavey Forum
suggesting this may need a 'electronic modification' to put it right.
Hope this helps.
Dec 30, 2014 | Music
Peavey tnt 115 blowing fuses
your either overloading something cause that's what pops fuses. My guess is that what your plugging in or into has a ground issue. I'm wondering if it does it with nothing plugged in at all. I would say if you have nothing in and it does it, you need to find where the ground issue is. that's my best guess
Feb 20, 2014 | Peavey Electronics Peavey Tour Tnt 115...
Very unlikely, sounds like it's faulty. Was this on plugging in or were you using the amp, and if so doing what? What is your supply oltage?
Jan 09, 2014 | Peavey Electronics Peavey Tour Tnt 115...
My peavey escort 2000 system starts up works and runs for about 10 to 15 minutes then shuts down and and green light flashes system restarts then shuts down continuously
If after you shut it down and after a while turn it on again and it works the same way. It sounds like a heat problem. We here at Pro Line Music are a Peavey service center. If you can not get any local help you can send it to us.
servicedepartmentprolinemusic@comcast.net
Jun 17, 2011 | Peavey 00511800 Escort Portable Sound...
PEAVEY ESCORT 3000 SOMETIMES THE EQUALIZER LEDS BLINKING AND STOP WORKING
Are you Pushing the system over its limits by Peaking everything. Sometimes they auto Shut off if your pushing to hard.
May 13, 2011 | Peavey Escort 3000 300 Watt Portable PA...
The power of the Peavey Escort 3000 Portable PA Sound System went off while in use, and since then power is not showing any more
A failure probably occured in one of the power amps and has blown the fuse or worse. DO NOT replace the fuse and try to operate it as further damage may occur. Take it in for repair.
Feb 15, 2011 | Peavey Escort 3000 300 Watt Portable PA...
Two time the peavey escort 3000 fault dawn then a turn off and then turn on and funtion again.
Sounds like an imminent failure ready to happen. If it takes a bit of time before functioning, it may be getting overheated.
This is a small system... don't overdrive it as it is intended for SMALL venues of say 600 square feet.
Feb 10, 2011 | Peavey Escort 3000 Packaged PA Speaker...
What kind of fuse is needed for the Peavey Escort 2000?
Hello. It takes a 5amp fuse, available at any auto parts store. Regards, J.
Feb 25, 2010 | Peavey Escort 2000 Microphone
Peavey escort
I would try unplugging some of the extras. All of that could have been causing your line voltage to sag too low for the mixer supply to operate properly.
Jan 17, 2009 | Peavey 00511800 Escort Portable Sound...
Peavey Escort 2000 Microphone Logo
338 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Michial Gueffroy
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
