Question about Compaq Computers & Internet
Monitor has a message input signal out of range
    President:
  • 2,961 Answers
This means that the screen resolution set in windows is too high for the monitor, or the pins are bent in the vga connecting cable
Posted on Aug 24, 2008
  • 94 Answers
Then.. we can clearly say that there is a problem with the tower... check for the proper power supply to the Tower... and check for the lights comingup on the tower or not..
How do I retire a Signal out of Range error message?
Go into HP screen menu and turn off the display notification
May 04, 2014 | Lenovo Computers & Internet
The input signal out of range on screen persists in spite of all monitor and PC video settings being correct.
Have you tried uninstalling the graphics driver entirely and then rebooting? Could be a corrupted driver.
Www helpouts google com
Try resetting your graphic to default and reset the monitor to factory default.
May 04, 2014 | Televison & Video
Input error
If you are getting the no input or out of range message on your screen then you will need to do one of the following:
No input
If you aren't getting signal then it means that your graphics card has failed. Make sure the video connectors are secure. If all connectors are in place and you still don't get a signal then you will need to:
Connect the video cable to onboard graphics if you were using a graphics card. If you're not using a graphics card then it means that your motherboard vgraphics has become faulty. You will need to consult a repair technition.
Out of range message
If you are getting this message then you will ned to change the refresh rate on your monitor. To do this boot your computer into safe mode by pressing F5 during boot up. Then right click on your desktop and click on properties. Then click on the Settings tab and click Advanced. Once in the Advanced settings click on the Monitor tab. Then all you will need to do is set the refresh rate down to a lower setting like 60 Hertz.
Feb 19, 2011 | Acer X183H 18" Monitor
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Screen goes blank and message comes up saying "input signal out of range"
When does the screen go blank? Also what do you have plugged into it this most likely just because your input signal may be set at to high a resolution or frequency. Once I have more information I can assist you further.
Thanks,
Lee
Aug 11, 2009 | LG Flatron L1515S 15" LCD Monitor
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Computers & Internet Logo
145 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
