Question about KitchenAid KT2651X Epicurean Stand Mixer
Kitchenaid mixer arm lift
The handle that lifts the bowl on my moms kitchenaid mixer is stuck, you can move the back part with the arms up and down and it moves the handle a little bit but otherwise nothing.
  • Julie Hamlin
    Julie Hamlin Jan 01, 2013
    I have the same problem, but mine is because I'm stupid. I kept the mixer on a bottom shelf where you had to tip it on its side to get it under the lip of the shelf. Well, genius me tipped it sideways by the arms and picked it up by both of them. The lifter never worked again. The repair shop wants $50 bucks to fix it. I already paid the guy $65 to replace the motor.
5 Suggested Answers
SOURCE: Bowl Lift
Same problem here, went from working perfectly to mix cookie, now I can barely move it...help!
Posted on May 03, 2008
  • 22 Answers
SOURCE: Kitchenaid pro stand mixer will not turn on
How comfortable are you with electrical parts? With the mixer UNPLUGGED and the switch ON measure resistance between the (flat) plug pins. If it's infinite (no meter movement) which is to be expected, there is an open circuit. The switch could be open or the wire to the switch could be disconnected (improbable) or the motor could be burned out and open (not very probable).
Maybe you could take the switch to a shop and have it tested.
This is not really a solution, just step 1.
Posted on Mar 14, 2009
SOURCE: My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
Posted on Jan 25, 2010
  • 130 Answers
SOURCE: KitchenAid® Professional 600? 6-qt. Bowl-Lift
nice machine!! enjoy using it. I assume you have no problems with it since no problems are described!!
Posted on Feb 23, 2011
My bowl lift lever on the hobart (bought off ebay) K5ss doesnt lock the bowl into place. What do I need to do to fix it, or at least figure out whats wrong if something needs to be replaced.
On a bowl lift mixer there is a small metal clip on the back of the bowl support arm, it works in conjunction with a small "NIB" on the back of the bowl, when you put the bowl on the support arm there are two pins that the bowl rests on, on each side of the support arm, you place the bowl on the pins then press down the rear of the bowl untill the nib locks into the clip, if the bowl is not locking in place then one of four things are wrong, one of the pins are not on the support arm, the NIB on the back of the bowl has come off (it is spot welded on) or the clip at the yolk of the support arm has worn down or broke in half and there would be no locking action without it. The pins or the clip are inexpensive if it is the Nib on the back of the bowl you will need a new bowl. Hope that helps if not pleases get back with us so we can FiXya.
Oct 14, 2014 | KitchenAid K5SS Heavy Duty Commercial...
What is the best way to identify what model Kichenaid I mixer I have?
If you cannot read the model from the band then look for the sticker. Most often it is underneath the base of the stand.
Jul 10, 2014 | KitchenAid KP2671 Professional 6 Series...
I removed the beater to bowl screw. how do i fix it?
Hi Mary, There is no such thing as a beater to bowl screw. If you screw the beater to the bowl then it cannot turn without also turning the bowl. Here's a link to an exploded view
https://www.manualslib.com/manual/413887/Kitchenaid-Kt2651xww.html
Jan 16, 2018 | KitchenAid Kt2651xww Epicurean 6-Quart...
Lift bowl kitchen aid mixer head wobble
what model, there are two different types. post 2002 and pre 2002. need more info
Sep 07, 2013 | KitchenAid Kitchen Aid Arm, Bowl Lift
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Bowl lift broke on 6 quart mixer
depending on the model and COLOUR of your mixer the part numbers could be as follows:
3179300 - white
3179311 - onyx black
3179318 - empire red
w10158518 - silver metallic
the bowl support arm includes pins as well. hope this helps
Thanks
Sep 10, 2009 | KitchenAid Food Mixers
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
Bowl Lift
Dec 31, 2007 | KitchenAid KT2651X Epicurean Stand Mixer
KitchenAid KT2651X Epicurean Stand Mixer Logo
211 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
