It comes up with options start normally go to safe mode or last known good configuration iv tried them all an it just goes back to the same screen
Na m8 tried tht if u hav anyother ideas plzz tell me thx anyway
Posted on Aug 27, 2008
Na m8 i tried tht if u hav any other ideas plzz tell me thx anyway
    President:
  • 2,961 Answers
You may be in a loop, when it boots back up, press and hold the power on button until it turns off, turn on again and it should start as normal
Posted on Aug 24, 2008
My daughters acer one will not upload. She unpluged and closed when it was updating 118 updates, well thats what she told me. Now it goes to a screen with Safe Mode, Safe Mode w/ Networking, Safe Mode w/...
There is a simple solution for you, just move to safe mode and then run in safe mode. After same mode chose option of Restore and after restarting once again run in safe mode then restart and start with normal windows.
Your issues has been resolved.
Good Luck --- Thanks
Aug 14, 2012 | Acer Aspire One PC Notebook
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
Received 512 - chassis fan error on HP Compaq dc5100 ff - I replaced the front chassis fan after detecting fan was not working now when I attempt to log into windows - windows screen appears than...
By enforcing the option to return BACK TO THE LAST KNOWN GOOD CONFIGURATION you have nothing to lose. Respond if you have already selected that option with no success?
Bruce
Jan 12, 2011 | HP Computers & Internet
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Restarted computer and it will not start successfully. Error message provides options for restarting in 3 safe modes, last know configuration, or normally. Tried all options and each time, Windows screen...
If you have a recovery cd, use that. Set your bios to boot from cd.
Sounds like the hard drive has crashed and you may have to reformat it and reinstall the OS...or change it.
Aug 14, 2009 | ASUS Eee 4G Notebook
I was hopeing somebody could help, this morning i went onto the laptop and then restarted the laptop, when i restarted the laptop the laptop kept on rebooting its self. i first comes up with compaq logo,...
Try to start in safe mode, then change the start up options so that the computer does not reboot on error. Then you can see what the BSOD (stop error) message is and troubleshoot from there.
May 05, 2009 | Compaq Armada E500 Notebook
Computer continually rebooting problem
You could try a windows repair install.
Apr 19, 2009 | Compaq Armada E500 Notebook
Laptop Will Not Boot
chose start windows normaly
Apr 14, 2009 | Acer Aspire One PC Notebook
Help :( i can't start up my laptop it wont let me :(
what i can help this...
you select safe mode and remove video driver and reboot your laptop...if it inside the windows normally,try to remove some unused toolbar in add and remove programs..and check also for virus scan..and reboot computer..
Dec 16, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Computers & Internet Logo
David Payne
David Payne
