Question about Cameras
SB-20 flash wont turn on
Left batteries too long in my SB-20. I cleaned up all obvious corrosion (only saw it on the door) with a brass brush and it still will not power up. Any advice?
Same thing happened to me. I just took a screwdriver and tried to scrape all of the corrosion - I was able to get enough off for it to work. If that didn't work, I would've gone ahead and put the door in a glass of coke and leave it in there for a day.
Posted on Sep 17, 2008
Makita circular saw wont run properly
Something more sinister. I think the armature is bad. (The center part of the motor that spins) Look at the brass bars on the comutator...where the brushes ride....there should be a nice even dark stripe the width of the brush all the way around. If one or two bars a discolored beyond that it's not good. Or if there is heavy pitting in between bars it's also not good. And lastly the more obvious sign is bars missing from the comm..
Dec 22, 2012 | Saws
My SB 600 flash won't turn on. I replaced the batteries and still won't turn on. Anything else I can do?
Answering a question with a question may solve your problem.
The batteries you took out of the flash unit were they dead and how long had they been sitting in the flash? If the batteries had no life left and had been sitting for some time it's possible that there is corrosion in the battery compartment. That corrosion will look like white powder or could even be black. You will need to get that out of there and clean the contacts, don't get that stuff on you or blow in the compartment in case you have it come up into your face or eyes. If the compartment is clean it's a good possibility that the batteries were installed incorrectly all it takes is one to be out of sequence and it wont' work.
Dec 10, 2010 | Nikon Speedlight SB-600 TTL Flash
I left my speedlight sb 600 with the batteries on for to long. now does not wor, it was a white pouder on it.
That white powder is battery acid, if you have been handling the batteries wash your hands well with soap and water it's very corrosive. Dispose of the batteries and start cleaning the battery contacts. I have used long swabs and rubbing alcohol to get the bulk of it off, clean the complete area then use a new eraser on the end of a pencil, make sure the rubber dust you create is cleaned out as well from the battery compartment. I have used a hand blower with the battery compartment facing down. Don't blow in it with your breath some of the material may enter your eyes. Again it's corrosive take precaution not to get that white powder or the alcohol wet swab on anything because it will eat it away. The contacts must be clean for the battery to make connection, try a new set of batteries to see if it powers up. If not remove the batteries and put a small bit of abrasive paper taped to the end of a pencil and sand of the contacts gently. Clean the area with the alcohols swab again and blow dry with the air blower/puffer. When dry reinstall the batteries and it should work. Always remove batteries from your gear when it's sitting for long periods of time hope this helps
Dec 02, 2010 | Nikon Speedlight SB-600 TTL Flash
SB-600 flash suddenly dead. Found some early corrosion on the AA batteries. What happened? Repairable?
Hi degossman, Corrosion is sometimes a fix us users can do. Other times it must go in for repair. What happens is the corrosion may leak past the point we can see in to the internals of the housing eating out wiring.
Nikon digital 1-800-645-6689
Nov 30, 2010 | Nikon Speedlight SB-600 TTL Flash
I put batteries in the flash which were bad and now there is corrosion as a result. Now the flash doesn't work. Can it be fixed??
yes, if the corrosion is not to bad. you can use the eraser on the end of a pencil to remove the corrosion if this fails use a small paint brush (artist) and paint the terminals with vinegar. The corrosion is alkali and the vinegar is acidic (and about the same ph) you will see the corrosion foaming as it is being neutralized. Once done repeat with clean water to eliminate the acidic vinegar.
Mar 31, 2010 | Nikon SB-28DX TTL Flash
New batteries but wont turn on - Kids Vtech Camera
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 07, 2009 | Vtech Kidizoom Digital Camera
Cannot get the unit to turn on, I have changed the batteries and the unit is absolutely dead, any ideas?
Clean the battery contact inside and on the battery cover with a pencil eraser. Just rub on them until shiney. DO NOT use sand paper or anything abrasive since that damage may may it more prone to corrosion. If cleaning the contacts does not work it will need to be sent to KNion.
Oct 21, 2009 | Nikon Speedlight SB-600 TTL Flash
Flash will not turn on.
Check the battery contacts are clean and not corroded, apart from that you have covered the most obvious cause. Probably need to be sent off for repair.
I might be interested in this if you decide to sell.
Ta
Mark
Sep 28, 2009 | Nikon Speedlight SB-600 TTL Flash
Turns its self off while driving
Usually the problem is due to corrosion on the battery cables at the battery. You must check under the red and black stud bolt covers. It is not always visible from the outside. Carefully pry the bolts out and clean inside with a small brass wire brush. Use a corrosion inhibitor when reassembling. REMEMBER: Always wear saftey glasses, acid resistant long sleeves and gloves to protect yourself from the corrosion. It is acid.
May 15, 2008 | 1996 Oldsmobile LSS
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
