Question about NetGear WGT624 Wireless Router
Tropical Storm Fay has confused my router!
Hi. I've had a lot of recent blackouts lately from Fay and now I can't use my router! When the power came back on, I noticed that my devices were no longer able to find my network, so I reset my Westell modem for at&t dsl and my d-link router. When I opened up my browser, at&t wanted to know my login information, which I had forgotten, so I reset the password but I still wasn't able to get on the internet with my router connected to the computer. When the modem was only connected to my computer then I could get internet, otherwise when the router was connected to the modem and my computer I couldn't. I decided to change to a netgear router but the problem still persists. I told both of them my password change and that it's PPPoE. What's the deal?! Thanks. I read about you guys in the paper.
  • 89 Answers
If you have reset the modem then it will be un-bridge already. the configuration you need to the router is Automatic Configuration-DHCP and not PPPoEand change the local ip address of the router to 192.168.2.1 to avoid ip adress conflict between router and modem.
Posted on Aug 24, 2008
Key won't turn in ignition on 2006 chevy cobalt
on a lot of these late model computer base cars when battery power get low the computer gets confused. try this disconnect the neg. battery cable. charge the battery. reconnect and try again. my son cobalt battery went bad key was stuck in the igntion. good luck.
Dec 19, 2017 | Chevrolet Cobalt Cars & Trucks
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
Cannot connect to Wireless with my Linksys WRT120N Router.
If you have 2 devices not be able to connect to it suddenly, then it is probably the router that changed, as opposed to it being the 2 devices changing at the same time. Sometimes wireless routers just go bad like that.Try a factory reset, and then set the appropriate settings back to where you need them. If that doesn't help, you likely need a new one.
Feb 09, 2012 | Linksys WRT120N Router
Hi i've forgotten the password i set for my router about 18 months ago, so i can access wifi on my ipod touch, i've tried to reset and restore to factory settings using the button on the back,...
Since you reset the router, the username and password were set back to its default values as well. For Netgear, the username and password is: Username = admin Password = password
Aug 29, 2011 | NetGear WNR2000 Wireless Router
I plug it in and there is no power the light is not on
Hi stella_bella,
I see that your D-link Router will not turn on or power up as you mentioned.
If I may ask Have you tried a different power source / Outlet?
also try ti find a different adapter with the same wattage on it and see if the Router will power ON using a different Power Adapter.
When did you notice your D-link not powering ON? was there any power surges lately, that can cause Router or Modem to get busted or damaged if ever you were either online or if the Router was turned on during the power surge.
The only thing you can basically do is try a different Power outlet or power source and a different Power Adapter of the same wattage to avoid damaging the Router more.
I hop that this helps.
Have a nice day,
mvincentc
May 08, 2011 | D-Link AirPlus DI-524 Wireless Router
Passwod
Hi!
Default username/password are:
Username: none (leave blank)
Password: admin (all small letters!)
If you've changed the default password, you'll have to reset the device, using the reset button on it's back.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Apr 21, 2011 | NetGear DG834G Router
D-Link DIR 300 router - Status LED and router doesn't work
Hi! I have a D-link DIR 300 wireless router.. I have the same concern before. what I did is, I did the hard reset by pressing the reset button for 20secs and after 20secs and the reset button is still press, I unplug the power from the back of the router and after 2secs plug in while reset button is press and press it for 30secs.. after that I unplug the power and plug in after 15secs. It should work, then u need to setup again the router in order to talk to the modem, if not.. and the device is still under warranty it needs to be replace...pls call your router manufacturer for replacement or if its still under 30 days, go to the store were u purchase the router.
Dec 17, 2008 | D-Link DSL 300 Modem
Good Signal,Good Mbps, Slow Internet Connection?
1. Try to use a different wireless adapter on all available USB ports, if the problem remains then
2. turn off your PC unplug the power cord from the power socket, short the two legs of the power cable then leave it for 5min, then plug it into the power socket again and turn on the PC.
if this didnt work then you have a hardware problem with the USB ports.
let me know how it works out.
Nov 30, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
I think I added "liquid" Freon to my Cars A/C, what do i do?
yes purge it and pull vacuum then recharge it should be around 30or so lbs
Sep 21, 2008 | 2000 Honda Civic
Belkin WirelessG Plus Mimo
Check all other wireless devices within the range of the router, cordless phones, cellular phones, etc.
Change the wireless channel on the router or possibly the other wireless devices.
2nd: check the Keep Alive setting in the router configuration if you have DSL. Set this accordingly
Nov 19, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
NetGear WGT624 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
