Sata ok thanks for your help if i put visa will that have the drivers i need? and is it the xp disk with sp3 on it ?
  • supercrook
    supercrook Aug 25, 2008
    thanks i will try that
  • supercrook
    Problem Solver:
  • 7 Answers
IF you put Vista it will have the SATA drivers you need.
Not sure what you mean about the XP disk.
You can use any XP CD to slipstream. While the ideal CD to use would be XP SP2, you always slipstream in the SP2 on top of the base XP CD.
I would advise against the SP3 as it still has issues. And SP3 still doesn't have any SATA drivers.
Once you create a slipstream XP CD, even if it is the baseline XP without any SP on it, you can always add them through Windows Update.
Posted on Aug 24, 2008
When i installing windows xp sp3 show no hard disk found
If your laptop is installed with a SATA hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 25, 2012 | Computers & Internet
I have an asus p5rd1-vm motherboard. I found problems on installing windows xp using sata hdd. Please help me to install windows xp2 as i am not using floppy drive.
The Windows installation CD does not have a SATA driver. You need a SATA driver of a floppy disk or turn off SATA native driver in the BIOS.
Please click on this link and follow my instructions on how to Install Windows on a SATA hard drive :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
I suggest you install SP3 (service pack 3) rather than SP2, it contains the latest bug fixes. The SP3 cannot be installed from a floppy, it can be downloaded from Microsoft, it is a large file approx 300Mb, I suggest you install it from a CD if you can borrow one.
Aug 09, 2010 | ASUS P5RD1-VM Motherboard
Require drivers for downgrading compaq presario cq60-110ei vista to xp sp3. john
most of the drivers in vixta work on XP but if you have a sata disk you need the drivers from that disk look up in the home page of the manufacturer,use previous drivers of the same model usualy works
Jan 20, 2010 | Computers & Internet
Installallation of xp
the xp does not recognize the SATA hard disk of your computer, you must install SATA drivers during the installtion of XP.
Sep 16, 2009 | Microsoft Windows XP Professional With...
Installing XP SP3 pro on my presario C700
Most likely you have a SATA drive which windows is not detecting. Restart the setup and press F6. You will need to use another system to download the SATA drivers and save to a disk. Then when prompted you can insert the disk. You can also upgrade to XP professional which will almost always recognize the SATA drives. Good Luck.
Jul 30, 2009 | Compaq Presario 700 470024-192 Notebook
Halt error 4 when installing XP on Vista
XP does not have a SATA driver on the installation CD, you need to either download a SATA driver and when XP ask at the start of the installation you need to provide a SATA driver for the hard disk, press F6, the driver is usually installed from the floppy disk. Alternately if your BIOS will allow you to set up the SATA drive as a ATA drive, do so and after XP is installed then install the SATA driver.
Jun 06, 2009 | Acer TravelMate 5530-5207 Notebook
Vant to install XP on my Acer
you need the sata driver problem is you have to use a floppy disk to put it in... or have it slipstreamed on your cd or get a copy xp with sp3 supports sata installs
Jun 05, 2009 | Acer Computers & Internet
NO INTTALEDWIN XP IN SATA HDD
you need your windows xp disc preferably slip streamed with SP 2 or SP 3 and then you should be able to install it onto your sata hard drive.
If you are having issues then you may need to extract the sata drivers onto a memory stick or floppy disk and press F6 before windows xp loads and specify to use the sata drivers which you can download from the motherboards manufacturers website generally as a zip file which you will first need to extract into a folder.
If that does not work using the memory stick you can use nlite to slipstream the drivers with your windows xp disc :
Nlite download
if you need more help post back
Apr 11, 2009 | Mercury KVM800M Motherboard
Installing WIN XP SP2 in aToshiba Satellite A205-S7459 Vista original
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
simple solution: get WINDOWS XP CD with SP3 it contains support for sata drives
Workable Solution:
this specific model of Toshiba was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from www.intel.com and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from www.intel.com select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
SATA DRIVER FROM:
http://downloadcenter.intel.com/license_agr.aspx?url=/17268/eng/iata87enu.exe&ProductID=2800&agr=Y&sType=&PrdMap=&DwnldId=17268&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
http://www.nliteos.com/
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
http://www.zimbio.com/Laptop+Reviews/articles/10840/How+Integrate+Floppy+SATA+RAID+Driver+Windows
http://lifehacker.com/386526/slipstream-service-pack-3-into-your-windows-xp-installation-cd
after windows XP installation u will have one more task to find drivers for ur notebooks with XP support but it is the next step if ur some hardware like modem / sound/ doesnt work then i can help more
pls let me know if i can help u more
and rate me FIXYA if i have fixed ur problem
Mar 03, 2009 | Computers & Internet
Trying to install wd 160gb sata drive on xp home sp2
try a newer xp version (sp3)
or custum build u;re xp, use nLite for it ...
Also in bios u can use the "ide mode" on the sata drive, if u have that option! (it wont afect u;re performance !)
Dec 11, 2008 | VIA JetWay PM9MS Socket 478 PM800 Micro...
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
