You probably had a power surge. Was the console plugged into a relatively new and reliable power strip, or was it plugged straight into the wall? If you don't have it on a surge protector, power surges can tear apart the internal components of your system. Unfortunately, there is really no easy repair for this. The easiest fix is probably just buying a new system.
Try replacing the power cable, many times when there is a power surge and you do not have a surge protector it will burn out the transformer on the power cord. If you replace it and still nothing, most likely your Wii has been burned out by a power surge.
This probably didn't happen, but my guess is that, when the sudden power was restored, the Wii console took too much and fried the circuts. This can happen on on computers, but I'm not sure about gaming consoles. This can be prevented with a surge protector, a device with several power outlets and a switch for power protection. If the warranty on your Wii is still present (I think it lasts 1-4 years) you can send it in to Nintendo for repairs (or if they can't repair it, they'll send you a brand new one).
You can try a new AC adapter.If that does not work,it will need to be repaired by a Nintendo authorized center.(I used to work at one).If you do by a new one PLEASE buy Nintendo brand.The "off" brands usually end up in some kind of problem down the road.
Good luck and agme on!
It seems every 5th problem I see is this issue. Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii or in the Owner's Manual.
This
is a common problem with the Wii. It happens
almost every time there is a power surge or the power goes out, etc. Even
if it's hooked up to a surge protector, this happens.
Power will come back
on, or you'll go to turn the Wii on one day, but the Wii appears dead. It won't turn on, and the LED indicators
won't light. If there was a power surge, or the power went
out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset.
Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug
it from the Wii, it has to be at the outlet. You have to kill power to
the adapter.
Unlpug it from the wall/surge protector outlet,
and leave it unplugged for 5 or 10minutes. This will kill power to the
AC adapter, and give the circuit time to reset. When you plug the
adapter back into the outlet after 10 minutes, the red led on the front
should be lit up.
Unplug everything! There is a "breaker" in the power supply and it may need to be reset. Just unplug all cables from the TV and outlets. Let it sit for a couple hours then plug everything back in and it should work fine. If not then the power supply has shorted out due to a strong power surge. You can claim it under your home owners insurance or call Nintendo and try to get it replaced. Thanks! Good luck and happy gaming!!
Unplug the power adapter at both ends (at the console and especially at the power outlet). Give the capacitors at least a minute to completely dissipate residual energy. Then, hook it back up and it should be good to go.
I would give credit to someone else for this super simple solution. But, it's all over the internet.
