Question about Kenwood KDC-MP528 CD Player
No sound I have all my wires connected properly and i have function on the radio i can go through all the options but it does not however have any sound in CD or tuner mode or anyother mode for that fact. what is going on here?!
    New Friend:
  • 161 Answers
Could possibly be a defective unit....try bringing it back and switching it out for a new one of the same model.....
Posted on Oct 01, 2008
2008 Jeep Wrangler that keeps dying overnight. The radio lights stay on all the time. But I have no sound from the radio. IF the radio does give sound I cannot adjust the volume.
I don't know if this will help or not but check all the grounds and the wire harnesses for bad connections---you may have a parasitic ground issue---that's something that is consuming power via thru other systems to function therefore not completing it's circuit properly
Sep 30, 2015 | Jeep Cars & Trucks
Only tweeters are working while playing radio. No other speakers are working. ...radio operates normally, turn on , cd, all options work. What could this be? It's a 2006.
all speakers r connected to the same wires on the radio
If left/right balance and front/rear fader work properly
and sound is coming out it is likely (but not definite) radio is ok and speaker wiring is the issue.
HOWEVER, if it sounds the same on both left and right, it could be the radio. It is unlikely both sides have the same issue at the same time without it being in the radio.
The only way to verify it to disconnect the speaker and substitute a known good speaker.
So back to troubleshooting.
Dec 09, 2014 | Cars & Trucks
What do i have do by to make my alpine iva-d310 work insted of being blank
It Depends On What Is Wrong In The First Place... (Note) Make Sure Your Radio Is Hooked Up Correctly! All The Wires Have To Be In The Correct Places for the radio To Function Properly, Its Probably Color Coated So Just Match Wire to Wire From The Radio To The Harness, If U Dont Have a Wire Harness That Matches ur Vehicles Model Or Harness Then U Will Have to Go And Purchase One At Wal Mart Or Best-buy,If U Already Have The Proper Set up And Ur Radio Is Hooked Up Correctly And Its Still Not Working. If U Can Here Sound But No Picture then It Is Most Likely Your Lcd Ribbon That Connects From The Main Unit To The Flip-Out tv Screen, Hope This Helps :-)
Mar 11, 2011 | Alpine IVA-D310 Car DVD Player
My radio on s430 lights up but no sound
You need to give more information.
Assuming you have incorrectly installed the radio, it can be but a few things.
The radio may not have the all power connections connected. constant and acc.
"I had this problem before."
The proper grounding.
If the wiring is incomplete it will only light, but is not officially able to function.
If it was working prior to this event, it is again incomplete wiring. (blown fuse.)
Mar 16, 2010 | Car Audio & Video
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
Hooked up a DURABRAND CD Stereo in my '97 Ford Expedition, because the old factory radio went dead, I got the proper Ford wiring harness for the stereo and proper mount. Every thing is getting power and...
because you have a built in factory amplifier that has to be bypassed. another option is to buy the kit that they make so you can USE your factory amplifier.
Jul 31, 2009 | Durabrand Car CD Player and AM/FM...
I have no sound when plaing radio ones i turn on system.
i don't have this particular system but that problem sounds familiar. When i've run into this problem, i noticed that i had pressed the function button one too many times and so just as the radio channel came on, it slowly faded out and the system changed to its next function which was the dvd player. First make sure the fm antenna, or am loop, is connected properly and there are no bare wires exposed or touching anything metallic.
Mar 12, 2009 | LGDVT418 System
No sound new install
More information would be required to help you with this problem properly. If you are using an amplifier and have no sound from it, you may just have the remote turn on of the amplifier not connected. The radio should have a blue wire coming from it and that would be the wire that goes to the amplifier to turn it on when the radio is turned on. If the radio has no sound coming from the speakers connected directly to the radio, you may have a bad speaker, bad speaker wire, or even have the speakers connected wrong.
If you can please give me more information about the install, like what model radio, what type of amplifier, how you have connected the wiring, how many speakers and what the speakers are connected to (an amp or the radio), I can help you figure out the problem. But please understand, since I am not there to look at your install, I can not know how you have connected everything. Are you using a universal wiring harness to connect to the factory harness and your radio? Have you added extra speakers? What wires have you connected to the speakers? If you have an amplifier, have you connected the RCA output of the radio to the RCA input of the amplifier? There are many things that must be connected properly for a sound system to work, if you are not familiar with how they connect together you really should have a professional do it for you. If you furnish the needed information I will be glad to help you further. If you do not furnish the needed information there is really nothing more I can help you with.
Dave
Oct 12, 2008 | JVC Car Audio & Video
JVC KD-NX5000 NOT WORKING PROPERLY
I had the same problem, where the Sat radio, the bluetooth and the ipod were all non-functional. Turns out, they all go through one central hook-up, so you have to make sure that connection is good.
When mine did not show up or function, I looked at the install under the foot board of the front passenger seat that the installer did, and nothing looked out of whack. Upon closer inspection, one of the cables was had been pressed out of it's proper place and loosened enough to cause a bad connection.
I don't care for the install, but there was no problem with the equipment, so check all of your connections. Even to the point of pulling them out and reconnecting them to see if that fixes the problem.
Robert
Jul 08, 2008 | JVC KD-NX5000 Car Video Player
Kenwood KDC-MP528 CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
