Question about GE Energy Star WCVH6260F Front Load Washer
Takes hours to wash a load of towels
My GE WCVH6260 front loading washer does a great job washing regular loads, but when I put in a load of towels, or anything heavy, it can take 3 + hours to wash load. It is less than 2 years old, and I have had it serviced twice, but am told there is nothing wrong with it. Any ideas?
  • factoryguy Oct 04, 2008
    Yes, I have a very similar problem when washing towels or other thick items. They are sopping wet after a very lengthy cycle. It doesn't always do it, but lately it's happening more frequently.
    When malfunctioning, the washer can't spin at full speed. It seems to detect that the load isn't balanced, stops, turns back and forth for a while to redistribute the load, then tries to spin again. It'll do this many times, resetting the timer each for each re-try ... hence, the cycle takes a very long time and doesn't spin fast enough to dry the towels. If I open the door and manually re-distribute the towels it sometimes spins just fine on the next try. I'm guessing it could be one of three things:
    (1) bad "balance" sensor is too picky about tub shaking, (2) tub shock absorber struts (there are 4 of them) are too "loose", or (3) bad design.
    Anyone know how to fix this?
Sorry, I should have provided more info. I've been fighting this problem for almost a year (warranty almost up!) and the drain trap was the first thing I tried. It drains just fine. Nothing in the trap. No obstructions in the line. Tub is as empty as it can be when starting spin cycle.
Posted on Oct 08, 2008
  • 3 Answers
Just found out that there is a drain trap that can get clogged and needs regular maintenance. Take out the bottom panel by removing 3 phillips screws (7mm nut driver optional). Unscrew the trap (water will probably drain out so be prepared). Clean out debris. You may also have to remove the hose connected into the trap in extreme clogged cases. Just use pliers to release the hose clamp.
Replace the trap plug, hose (if necessary) and the bottom panel.
Good luck!!!
Bryan
Testing the control panel for damage on a front load washer
How to Diagnose Washing Machine Control and Program ...
? 9:08
https://www.youtube.com/watch?v=QYPqpjLV7s4
Nov 11, 2013 - Uploaded by eSpares
I have a bosch front loading washer that's doesn't have code board. .... there's a clicking behind the front ...
[PDF]GE Front Load Washer - Atech Appliance Repair Service ...
www.atechappliancetechnician.com/GE_Washer_FL_WBVH6240__WC...
Louisville, Kentucky 40225. 31-9135. GE Front Load. Washer. WBVH6240. WCVH6260 ... damage. The man u fac tur er or seller cannot be responsible for the ..... Service Test Mode . .... accessible on the control panel's 7-segment display.
Jan 05, 2016 | Washing Machines
When washing a load the machine is not spinning.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 17, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE Front Loader Washer
Towels are heavy so it likely became unbalanced and triggered a shutdown.
press the signal button for 10 sec
Feb 26, 2008 | GE WSXH208A Front Load Washer
try unplug and leave for 30 min
please give me machine number so i can help you further
The washer smells
I Talked with a retail appliance sale's person about two weeks ago because I had the same problem. Buy a can of country time lemonaide and put three scoops into the drum and run it through a regular wash cycle. This removes the odor. Also around the rubber door seal you can pull the rubber back from the drum side and wipe around the seal with lemon juice due to water and detergent being trapped in the seal. Once every month should do the job. It works for me.
Nov 01, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
266 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
