Question about Humminbird GPS
Portable Humminbird 565
I bought a Portable Hummingbird Fishfinder 656 I put it together and hooked the up the battery, and pressed power and all I got was a screen that that was flashing between screen saying "Loading..." and and the start up page. Thats all that it did. Can this be fixed?
Thanks
I've got the 565 and everything will be working fine and then the depth
finder or bottom of the lake goes to 6ft. Have to shut it off for an hour and it works for a wile but it always goes back to doing it
anything I can do?
Thanks Jeff
Posted on Jun 08, 2013
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Humminbird fishfinder keeps blowing 5v
Most probable component that has gone bad and capable of blowing the 5V fuse would be:
  • voltage regulator IV or transistor;
  • reverse protection diode;
  • zener diode;
  • shorted capacitor.
As the 5VDC normally supplies the logic circuitry, perhaps diagnosis and tests should be focused within that area.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 24, 2008
Humminbird
My 787c2 screen just shows lines across it does anyone know were to get a new screen for it hummingbird says they don't stock them anymore try Humminbird Fishfinder Depth Finder Humminbird GPS Chartplotters...
Jun 14, 2013 | Humminbird Boating
I need a longer power cable for my humminbird 561, is it possible
don't splice them bad bad bad call hummingbird order you a set of power cables
Apr 11, 2013 | Humminbird 561 Fishfinder
I need a longer power cable for my 561 fish finder
they have longer power cables at hummingbird call em order you one
I broke the mounting bracket can I get new parts?
ggo to hummingbird website or call the company and order one and alot of times they will not evan charge you
Mar 21, 2012 | Humminbird Fishfinder 565 With Transom...
I did lost my operation manual for my fishfinder humminbird 570
Hi!
Since your unit isn't listed in their owners manual section, you'll have to contact their support rep.
http://www.humminbird.com/support/Contact_Support.aspx
Hope this helps you out.
Jun 20, 2011 | Humminbird Fishfinder 565 With Transom...
My fishfinder 565, just suddenly stoped working. We were in the boat and all of a sudden it went dark. Can there be a fuse of somekind that could be replaced?
yes, generally there is an inline fuse on the hot (red) wire. it is incased in a white sleeve that twists apart and reveals the fuse. if its not the fuse check the battery or connections to the back of the depth finder.
Aug 31, 2010 | Humminbird Fishfinder 565 With Transom...
I have a humminbird wideone fishfinder but no instructions
downloaded instructions from a web site many thanks any way
Nov 20, 2009 | Hummingbird Exceed 10.0
Hi guys, i bought one a year ago, and just got it
Hi!
If your 220 is in portable configuration (runs on 8 'AA' batteries) make sure that the batteries are 1.5 volts and not 1.2 or 1.3 volts. (1.2V times 8 batteries is only 9.6V)
Also check the battery compartment as we see leakage from some batteries which corrodes the connector plates that the batteries hook up to.
One more thing...check to see that the power cord is plugged into the unit with the notch in the plug pointing UP. The rubber plug housing on the sounder allows the cord to be plugged in backwards if it's forced a litlle bit.
Best of luck!
Mike
Sep 26, 2009 | Humminbird Piranhamax 220 Fishfinder
CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Jun 15, 2009 | Humminbird Fishfinder 565 With Transom...
Humminbird fishfinder 565
according to the manual... 10-20 VDC
Please rate this solution.. thanks
Feb 04, 2009 | Humminbird Fishfinder 565 With Transom...
GPS Logo
160 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
