Question about HP Pavilion a350n PC Desktop
HP a350n not powering up.
There is a green light on the back of the power supply that keeps blinking. If I disconnect the power supply from the motherboard the green light stops blinking and stays on. It started doing this after we lost power for three hours. We have the computer plugged into a Belkin power strip. This is our first major problem with this pc. Please help.
  • 1 more comment
  • terry6136 Aug 24, 2008
    The green light does stay stable and "on" when you disconnect the power supply wires that come out of the power supply and go down to the motherboard. The power is good. 120V continous. When I disconnect the power cord from the computer and the wires are connected to the motherboard the green light will still blink, slowly.
  • ptrobio Apr 04, 2009
    have an HP a350n. I put the computer on standby and it shut all the way down. It will not fire up at all now, totally dead other than the green light on back. that light is blinking now. when I open the computer and unpluged the power supply from the mother board the light goes solid green. I pulled the battery and then put it back, still nothing..
    im thinking the power supply is bad...any help would be great.thanks
  • Phani Kiran Vayuvegula
    Phani Kiran Vayuvegula May 11, 2010
    Generally the light on the SMPS for HP computer indicates the proper power supply... it should be stable green... sometimes there would be a problem with led also...
    i juz want to the power supply to the computer is continuous ??
Unplug power and open computer and pull the small battery and wait 30 sec and replace
plug in everything and reboot
may have to re-enter cmos utility
Posted on Aug 25, 2008
Hp computer green light keeps blinking
Green LED light on back of Power Supply?
(The power cable plugs into the Power Supply)
Bad Power Supply. Replace.
Need guidance? I can step by step you through it.
I need the Product Number, though.
This can be found on the Back of the computer, in the white
Service Tag.
P/N = Product Number
Post back in a Comment.
Mar 27, 2013 | HP Computers & Internet
Power problem .... tried 3 different power supply cords...the green light on the rear blinking meaning???? pushed switch on front ...held response only moved from 1 office to another....always...
was it dropped..?? the indicator light should b solid not flashing.. If you held the power switch in for several min an nothing Try plugging the cord directly into the wall. Do not use power strips as they may have failed.Toggle the voltage regulator switch from 115V to 230V then back again. If you are in North America, this switch must be on 115V. you may have a loose connection in the machine Lastly, you may need to go inside the case and confirm the thin wires running from the front power and reset switches are connected to the motherboard., to check be sure u are grounded an check all connections inside the computer... If the LED is still flashing, the power supply is probably bad.
Apr 28, 2010 | HP Pavilion a350n PC Desktop
Hp pavillion a350n green light on back blinks. after a power failure of three days my pc will not start. the pc was off before the power failure.
the green light blinking, is that near a network cable? It sounds as though the PSU has hung or had an issue. It might be worth trying to hold down the power button for around 20 seconds even 30 seconds. Then unplug the power and reconnect it. Try that and let me know.
Mar 01, 2010 | Video Game Consoles & Games
Green power available light flashing, will not power on
If this is the green led on the back of the computer, on the power supply it is most likely a Bestec power supply and it is most likely bad. Not guaranteed mind you but I have seen (and heard of) alot of these going bad and this is the symptom.
Jan 31, 2010 | HP Pavilion a350n PC Desktop
Bestec model atx 250 12z flashes green when hp pavilion a706n is powered on light on back blinks green and pc does not power on even after all cables are disconnected
Try these suggestions:
<a href="" >Troubleshooting Power Supply Issues</a>
Nov 29, 2009 | HP Pavilion a706n PC Desktop
Computer will not power up. there is a green blinking light on the motherboard.
did you try to uplug and plug back up?
i had that problem.
it was a short(i know because i cause the short)
i had a old motherboard dell celeron 2.0ghz and i just was bored and started touching metal to metal and it started to blink so check your motherboard
May 22, 2009 | HP Pavilion a350n PC Desktop
PC will not power up
Try to reboot your computer with the disk that it came with.=D
Apr 19, 2009 | HP Pavilion a350n PC Desktop
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
I have a Compaq SR 1000 desktop set and I can't get the power to go on. When I plug the unit in a green light in the back keeps blinking. When I disconnect, hold in the power button the blinking stops, but...
Hello shapscomp
The blinking green light is likely your Ethernet card's LED. Is the blinking light located near your Ethernet (network) cable?
It sounds as though your power supply has failed. You may be able to purchase a replacement power supply for it.
Would you like some assistance in deterimining if that is the case?
Thank you
Apr 05, 2008 | Computers & Internet
HP Pavilion a350n PC Desktop Logo
1,068 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
