Question about Kenmore Elite HE4 Electric Dryer
Washing machine error
Error F32 most common error given.
washing machine keeps stopping, giving a different error. only 5months old.
  • stachill Aug 28, 2008
    It was a power relay switch and was still under warranty. Thanks!
    Scholar:
  • 121 Answers
Hi! stachill
Sound like a power problem, or a connector problem between the three different IC control cards.
InMrFixIt
Posted on Aug 27, 2008
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
Jun 19, 2013 | Washing Machines
F32 error on Duet washer
f32 is pressure switch error. Disconnect the tubing and blow out the moisture and retry.
If no-go... replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 02, 2010 | Whirlpool Washing Machines
1 yr old machine, not filling w/ water. Starts, then gives error code F32
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer is throughing a code
Here's a solution from an old posting of the same problem in a different Kenmore washer:
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing thethree screws in the top back of the washer.
2.Inside the back rightcorner is a round plastic box, fastened to the side with a plasticsnap. In will have a wire connector and a small, rubber hose connectedto it.
3. Check to make sure all the connector wires areconnected and tight. Unplug washer for 30 seconds to reset it. If the cycle failsstill with the F32 code, you'll need to replace the Water Level Switch.
4. Ifthe Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Aug 09, 2009 | Kenmore Washing Machines
Error message f32 - not in manual
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
There is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
I get an error message F32.
F32 is a long drain fault code. Tip your washing machine back far enough that you don't have to hold it up. At the back of the unit there are two "things" with hoses coming out of them attached to the bottom of the outer tub. On the left is the recirculation pump, and to the right is the drain pump. Take a wet/dry vac and get as much water out as possible through the end of the drain hose, then pull the hose off the drain pump, remove the pump, and look for coins/shoelaces/whatever might be blocking it on the inside.
What make and model is your washer? This applies to Whirlpool cabrios. Just reread your message and realized that I have no idea what you're talking about. F codes are pretty common in different brands, but "32" could mean anything. All depends on what you're looking at.
Aug 24, 2008 | Washing Machines
F32 error code
remove bottom apnel on right side? is tech sheet with codes think f32 is pressure switch
Jul 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE4 Electric Dryer Logo
96 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
