Question about iLO LCT32HA36 Television
ILO LCT32HA36 will not power on
The unit will not power on with the remote nor with the power button on the right side of the unit.
  • 8 more comments
  • mjgoins2004 Sep 22, 2008
    Will not power on.Nothing I do will get it to turn on.Unplug it then powered on for a while,now this doesn't work .Thank you Marvin
  • Anonymous Sep 26, 2008
    Same problem,will not power on.Makes funny noise like it's trying to come on but doesn't.
  • queenie123 Sep 28, 2008
    Woke up this morning and tv will not turn on. Red light just stays lit. I've been doing the unplugging and plugging for months now. Blamed it on my kids PS3 but after reading this site, it's just a crappy TV. I've owned the TV for over 2 years now and no warranty. Called Wal-Mart and the KID said the light bulb was burned out????? Whatever!!!! Any other ideas to get it to come on besides going out and buying another tv?
  • Anonymous Oct 21, 2008
    SAME TV AND SAME PROBLEMS IM LOOKING FOR ANSWER'S TOO.
  • SirJosh0820 Jan 30, 2009
    I've had mine for a little over 2 years too. The standby light is on, but the picture is not coming on. I'm currently having mine repaired at a TV repair shop. I am aware of the problems with this  tv. I've been trying to go through the proper channels, but the number that customer support gives you has no answer. It was a great tv, until this happened. After reading evryone else's horror stories, I'll never buy store brand again. I'll keep updates to my situation.
  • SirJosh0820 Feb 04, 2009
    Just heard back from my repair man. Fortunately, my power supply was okay. Also, he found the parts locally. Although it will cost me 113.27 to have it repaired, it will get me by until I can buy a new and better hdtv. I wish I could have had it repaired by a manufacturer, but there is no one that you can contact. This has been an adsolute nightmare. Best of luck to everyone else.
  • Anonymous Apr 02, 2009
    tv does not come on, but it clicks like it want to.
  • brian_0 Apr 19, 2009
    my lct32ha36 will not power on. I opened it up to look at the power supply board. I couldnt find any suspicious looking caps or burnt areas as another poster suggested. I disconnected the output connectors of the supply to see if it would put out any voltages. It did not. In most supplies like this, they put out a standby voltage so the TV can respond to the remote. I did not see that either. The fuses in the supply are not blown. My supply is a VP210UG01. Does anyone know where I can get a replacement supply or have just the supply, not the whole TV, repaired? Or does anyone have any additional tips on how I might repair it myself?
  • duboy1 Apr 20, 2009
    I have the same exact problem as brian_0. Any solutions for it yet? My caps all look fine, i even replaced three that people suggested but it didnt make a difference. My onboard light does not stay on.... It momentarily flickers on when i plug the tv in.
  • brian_0 May 11, 2010
    Timezone88: What is the model of the ILO power supply you were able to fix? Is it the VP210UG01, or one of the MLT series? Does it have 5 connectors at the top of the supply, one for 24v, one for 12v and 9v, another for 24v, one for 5v, and finally one for 5v standby and on/off? What I would really like to find out, if I cannot find a replacement VP210 series, would a MLT series work in my TV.
    Sirjosh0820: What did your TV repairman say was wrong with your set?
  • 12 Answers
Same thing happened to my ilo. There are four capacitors that are bad on the power board. You can usually tell its bad because at the top it bulges out. Here is what you need to do. Unplug the tv, open up your ilo find the power board ( the power cord plugs into it). Then find the capacitors that are bad (they are the around things usually in blue color) and remove them by soldering the other side. On mine there where three 1000uf 16v and one 470uf 35v. Those are the ones that need replacing. I replaced them with a higher voltage rating 1000uf 35v and 470uf 50v. All you need to do is solder them back on but make sure you solder them back the right way (plus goes to plus on the board or you will be in trouble). I found the capacitors at radio shack for about 1.50 a peice. If you dont know how to solder look it up on youtube. If that does not work there might be couple more bad capacitors that need replaceing just need to find them and you can tell by a small bulging top.
Posted on Apr 14, 2009
  • timezone88 Jun 05, 2009
    If there are no bad caps and you are not getting any voltage then it might be a bad transformer. Check it to see if it has any burn marks inside the coil.
  • timezone88 Jun 21, 2009
    brian_0 if the power supply provides the same voltage and current then you should be able to use any power supply. but you should first check if there is something really wrong with your power supply. Just check the voltage on out put and see if it matches what the label there. If it does not then its the power supply. if the the voltage matches with the lables then it the circut board that controlls the power supply. I dont really remember the supply board that i had so i cant really tell you sorry. if you need some more help email me at timezone88@yahoo.com
    President:
  • iLO Master
  • 749 Answers
Buy another tv
Posted on Oct 17, 2008
    Problem Solver:
  • 10 Answers
Ok I have been doing these for a while now and I just finished one.Yes the caps in the power supply's go bad.And they come in a number of colors and there are different power supply's this one is the VP210UG01 ver 2.2 from the 32" an ILO LCD TV.Here are the caps I had to replace and sizes
Capacitors
1. c37 = 220uf @ 35v
2. c41 =1500uf @ 10v
3. c42 =1500uf @ 10v
4. c43 =1500uf @ 10v
5. c44 =1000uf @ 10v
6. c50 =1000uf @ 10v
7. c54 =1000uf @ 16v
replace them all I'm typing this repair using this Tv as a monitor now and it has been on for over 24 hours no problems as of yet.
Hope this helps someone out by the way the c54 cap was on the other side of the power supply but was bualged so i replaced it also.
Posted on Apr 24, 2010
I bought a new TV.That one still doesn't work
Posted on Oct 18, 2008
No signal found
Posted on Aug 24, 2008
Why does the screen cut off slightly when connected to laptop via HDMI?
There should be a button in the menu to fix this issue under picture.
Aug 22, 2014 | iLO LCT32HA36 Television
I found a ilo 32 hdmi t.v. model lct32ha36, there is not a button that says on/off. Just a standby. I want to figure out if it works before I by a remote to test it. Can you suggest anything?
Most new televisions are actually labeling the "power" button correctly. Unless a tv is unplugged, it is never really off. It just goes into a state of standby. This is what you would have called your power button.
Jan 03, 2012 | iLO Televison & Video
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
LCT32HA36 Won"t come on ,No lights, Nothing happens
Try website 1-800-Remotes Factory original.Buy an exact remote.
Mar 02, 2010 | iLO LCT32HA36 Television
My ilo tv will not turn on by the remot or power button
Remove back cover. Check to see if the fuse is blown. If not, check power from power supply to main control circuit to see if there is power. If not, the power supply is probably bad.
Oct 26, 2009 | iLO LCT32HA36 Television
Have ilo lct32ha36 and powers on and hear sound, but black screen
you have a bad master and slave inverter board these are the skinny boards that go verical on the back of the unit
take you unit apart remove back and look at the back of the tv face down on a blanket remove all the screens take the back off remove those two board going vertical look up both parts on google or call or go to shopjimmys.com
Oct 19, 2009 | iLO LCT32HA36 Television
TV doesn't come on 99% of the time.
Sounds like capacitors on the power supply have gone bad. There may be some that have domed,bulged or vented, on occasion they will also dry out, due to the heat of the panel. The damaged one you can see and the dry ones will have to be tested. Worst case will be if the board is bad and has to be replaced. Cost of repair can range from $150 and up depending on the repair shop fees and if the board has to be replaced.
Sep 04, 2009 | iLO LCT32HA36 Television
Ilo LCT32HA36 won't show a picture but does have power
Hi, I had a computer monitor that acted similar one time and what I found were that there were some bad capacitors in the power supply board inside. They were identified by the swelled up rounded ends and the heat discoloration of them. They look like little aluminum cans with a vinyl sleeve shrunk around them with the component values written on them. A normal one is flat on the end with no signs of any leakage around them of a brownish blackish substance similar to wax or tar. They are relatively inexpensive at an electronics supply store($1-2 each) so I replaced them all. This will require some soldering and electronic repair knowledge though. The power supply could not stabilize so it just kept shutting down the picture that only displayed for a brief instant.
Good Luck!
Jan 24, 2009 | iLO LCT32HA36 Television
Remote code
There is no code for the television you may be able to use a UN11000 - call 800-726-4405 - Ilo is made by ESI - who also makes the Akai, Viore, and Scott brand tv's.
Mar 03, 2008 | iLO LCT32HA36 Television
iLO LCT32HA36 Television Logo
2,637 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
