Question about Whirlpool LER4634J Electric Dryer
Help me with #ler4634jq1
My dryer will not heat up, also the knob will not move when it is running it will turn on but it only blows cold air. what should i do? I alredy cleaned trap and got no results
  • alex1rc Oct 20, 2008
    My dryer comes on but doesn't heat up, I change the heating element but didn't work
  • 550 Answers
Alex1rc
markhall 92
open the case as described elsewhere in 'replace belt' questions, I get tired of typeing, and examine the fan body and exhaust ducts for a thermal fuse
looks like
or
one shot device to cutoff current for over temp
If there is no conductivity through the device (remove 1 wire to isolate test with ohmeter)
replacements are ~$15 each, common to most dryers the local appliance part store will have them
or your local service guy can do it, I take ~15 minutes, and charge $35 plus parts, sorry not an offer, I am likely 100 miles away
Before you put the dryer back together
clean all lint from fan impeller fan housing and exhast duct, right to house outside wall, most common cause for blown thermal fuse
Posted on Oct 29, 2008
My dryer will not heat up, it is turning. could it be a fuse on the dryer? If so, where is it located?
Posted on Oct 11, 2008
  • 89 Answers
Contact the manufacturer of the device. some parts might need replacement already.
Posted on Aug 24, 2008
The selector knob on my Whirlpool LER4634JQ1 does not move, so the dryer will not turn off automatically and no "end of cycle" buzzer sounds. Do I simply replace the timer?
Your timer most likely does need to be replaced. The timer has a small motor that causes it to rotate during the cycle and those can go bad causing the timer to not advance. Unfortunately, you cannot get just that timer motor anymore. Hope this helps!
Feb 16, 2015 | Whirlpool Dryers
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
No heat / heater not working
not blowing air or when switch is on blows cold air when you have climate control knob turned over to heat? it could be a switch or blower motor or fuse if its not blowing any air. if its blows cold air when knob is on heat then is can be thermostat or low on coolant or it could be climate control module or it could be a air filter in dash.
Apr 05, 2013 | 1993 Mazda Protege
Dryer will not blow hot or cold air
what's the brand name and model number?i don't understand what you mean it won't blow hot or cold air?if you have the vent line off of the back and the dryer is running and you don't feel any air blowing out you could have a bad blower wheel,if you write back let me know if it's running and what it's doing.thanks
Feb 17, 2013 | Dryers
2007 corolla does not give off heat, blows cold. temp shows correct range, heater core hoses hot to the touch inside and out, radiator hoses hot and fluid is sufficient.Would thermostat be at fault even if...
there should be a temperature door, but I don't know if there is a cable or if its electric. turn the temp knob, if it feels like it moves anything? I dont have a diagram here at home, but will monday/
Dec 06, 2010 | 2007 Toyota Corolla
2004 mercury mountaineer.heat problem When turning ac knob to heat clicking sound like door opening and closing repeatedly sounds and air blows cold instead of hot.
Sep 13, 2010 | 2004 Mercury Mountaineer
My Whirlpool Dryer LER4634JQ1 (no heat)
most likely a thermostat that has failed, I'm having same problem and am just now learning how to test. research " testing dryer thermostats and fuses online"
Oct 08, 2009 | Whirlpool LER4634J Electric Dryer
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Whirlpool LER4634J Electric Dryer Logo
151 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
