Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Samsung SyncMaster 913v Monitor
I just started getting black spots on my Samsung Monitor one is the size of a golf ball and the other the size of a tennis ball. Can this be repairedor do I need a new monitor?
  • 89 Answers
If there are too many black spots already then that means there are lots of dead pixels on your lcd and it cannot be repaired anymore. that will continue to add more dead pixels and eventually damage the device.
Posted on Aug 24, 2008
My Samsung SyncMaster 913V (Black) 19 in. Flat Panel LCD Monitor, does not work correctly. Every time I reboot my computer the screen only works for a few seconds and after that it gets black and a...
Resolution setting of computer is not compatible with spec on monitor. Adjust computer res setting to agree with monitor and you will be good to go. If settings are ok then the issue lies within the innards of your monitor.
Apr 15, 2017 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The solution is open your look for the LCD monitor power supply module (which have PCB connector to the AC power), on that board look for capacitors, now look for broken one which upper part is bloated, like the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
Jan 22, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung SyncMaster 913V it's displaying red lines
Sometimes this happens when the pins on the vga connector are bent. You can either try to straighten them (very carefully with tweezers) - be sure to check both ends, or try a new cable.
Apr 06, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913v picture rotated 90 degrees
Please press Ctrl-Alt and your arrow keys until the image is straight!
Mar 10, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I have a Samsung SyncMaster 913v Monitor - black streak forming
Plug your monitor into another computer, If the line persists, it is your monitor, you need a new one. If it does not, It is your Video card, you need a new one. But it is one of the other...
Feb 20, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v color problem
Appears to be something in the connection. Check the video cable and pins on the video connector. Also verify the color settings have not been changed on the monitor. There should be an area where you change the RGB levels.
Feb 14, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor syncMaster 913v wont run 1280 1040 Resolution has in past goes blank moving "box- message' says ajust to 1280 1040 resolution Runs on other resolution settings ok
The problem is main board inside monitor which is needed to be changed with new one. So I suggest you to take monitor to the nearest samsung's service center.
Best regards
Jan 08, 2008 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
275 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
