Question about Dryers
Whirpool electric dryer: heat turns on but no rotation
The dryer stopped working in middle of the load. The heat is turning on but no rotation.
The dryer (LER7646E02, serial MH4086229, type 178-00) is 8 years old. Is it worth repairing?
  • 706 Answers
Your problem could be as simple as a broken drive belt.. or an overtemp switch.... If you've never replaced the drive belt.. then that is in all probability your problem.. If you reach inside the dryer drum and try to rotate it.. does it offer any resistance like it is turning a motor pulley system or is it free to rotate with very little resistance ( would suggest the belt broke).. If the cost to repair exceeds the cost to replace then you'd be better off replacing.. However ..if it is just a drive belt.. then I would just replace that.. Hope that helps...
Posted on Aug 24, 2008
How do you replace the door switch in a Kenmore 70 Series 68702 electric dryer?
What is the model number of your unit? Look inside the door area.
Nov 19, 2012 | Dryers
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
Not generating heat and dosnt stop automatically
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101 ,..,
Apr 03, 2011 | GE Dryers
I have a whirpool dryer Model LER 4634 PQ0. The dryer turns but does not heat. What could the problem be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Whirlpool LER4634J Electric Dryer
GEW9878LW Electric Dryer: Whirpool Dryer - Model # GEW9878PWO - Serial # MS4...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 18, 2010 | Whirlpool GEW9878LW Electric Dryer
Electric Whirpool Dryer doesn't stay hot
Check the vent for obstructions if all is clear do an ohm reading on your heating element. For video instructions go to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Whirlpool Dryers
Dryer won't rotate stuck on fluff
one of two things has happened the belt is broken or the electric motor has failed
Apr 13, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer does not heat all the time.
replace both the hight limit thermostat and low limit thermostat they come in a kit and also clean dryer vent
Dec 29, 2008 | Whirlpool LER5636P Electric Dryer
CDE6000W, Crosley dryer stopped working in middle of load
it could just be the motor going out some dryers only last 6-8 yrs some dryers continue to be quite even if there going out i suggest call a repair preson to see if repairing it is worth it
Here To Help
Shaun
Nov 17, 2008 | Crosley CDE6000 Electric Dryer
Electric Whirpool Dyrer Wont Run
your dryer needs a new motor
Sep 17, 2007 | Dryers
Dryers Logo
130 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
