Question about Olympia OL-5805 Cordless Phone
QuickTime movie mode
Can I play back sound on a movie that was recorded in QuickTime® movie mode?
    Master:
  • 852 Answers
The D-580 Zoom does play back sound in QuickTime® movie mode.
Posted on Sep 01, 2005
SOURCE:
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
Canon PowerShot SD1100 IS Digital Camera I used this camera to take movies. When I play it back on the camera and after downloading to my computer, it plays as if it's set for fast forward and there's no...
Check your camera settings in movie mode for the correct settings for time lapse, normal, slow motion and fast motion. A slow recording memory card will not produce your problem but will take longer to save the file. If you shot the movie in PAL and played it on an NTSC TV, the picture would be in black and white with no sound and vice versa. ALWAYS format the memory card in the camera, never on a PC
Mar 11, 2017 | Canon PowerShot SD1100 IS Digital Camera
The sound wont work on my camera
Most cameras from 2004 did not include sound on the video feature.
What does your user manual say?
From my little research using Yahoo Search, I have found that your camera does have a built-in speaker, but no mention of a microphone
NOTE: Movie and Sound Recording Modes"
The C-770's Movie mode is accessible via the Mode dial on top of the camera (marked with a small movie camera symbol). Once in Movie mode, you can record QuickTime or MPEG4 movies with or without sound.
So there you have it. You have to tell the camera you want it to record sound or not and that is going to be located in the user manual.
Mar 11, 2011 | Olympus Cameras
Panasonic tz5 movie files will not play in Windows only Quicktime
If the movies are recorded as .avi, then you will have to use QuickTime. One way to avoid having to select QuickTime each time is to hold the SHIFT key, right click over the video file and select "Open With". Now select QuickTime (otherwise select other programs) and scroll to QuickTime from the list and you should see a check box at the end of the list and make sure its checked. Here is a screen shot:
Now click OK and the next time you open the camera movie files, it will automatically open in QuickTime.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 28, 2008 | Cameras
Camera sound in movie mode
I had the same problem, try updating your software you play the videos with. I had the issue with Quicktime a simple update seemed to solve the problem for me.
Jul 16, 2008 | Samsung Digimax S500 Digital Camera
Sound doesn't transfer from camera into computer
It most likely IS the .mov file. I recommend buying quicktime pro, $20,  which will allow you to convert the file, or if you get the free version of quicktime, and the video and audio play fine with it, You can use a screen recorder and turn off the "record external Mic" mode, and turn ON "Record Computer Audio" Once you're done converting (or recording) You can go ahead and edit, Hoped this helped- sincerely: animation508 (youtub username)
Jun 18, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Record movies with sound
Yes. The Olympus C-60 Zoom Digital Camera can record movies in Quicktime Movie Mode, however it cannot record sound.
Sep 04, 2005 | Olympus Camedia C-60 Zoom Digital Camera
Record a movie in QuickTime Movie mode
After selecting Quicktime Movie mode from the mode dial, you can begin recording by pressing the shutter button. Press the shutter button again to stop recording the movie.
The Olympus D-395 Digital Camera can record movies in QuickTime Movie Mode, however it cannot record sound.
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Movie mode function
The movie mode function allows you to record short movie clips. The recorded movies can be played back or stored as still images using the cameras index function. Please note that the D-390 does not record sound in the movie mode.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Olympia OL-5805 Cordless Phone Logo
61 people viewed this question
Top Olympia Lands Phones Experts
ray gallant
ray gallant
Jose Ma DM.
Jose Ma DM.
Tom Chichester
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
