I get an error message F32.
I cannot find error F32 in my manual. My machine is only 5 months old.
    Problem Solver:
  • 9 Answers
F32 is a long drain fault code. Tip your washing machine back far enough that you don't have to hold it up. At the back of the unit there are two "things" with hoses coming out of them attached to the bottom of the outer tub. On the left is the recirculation pump, and to the right is the drain pump. Take a wet/dry vac and get as much water out as possible through the end of the drain hose, then pull the hose off the drain pump, remove the pump, and look for coins/shoelaces/whatever might be blocking it on the inside.
What make and model is your washer? This applies to Whirlpool cabrios. Just reread your message and realized that I have no idea what you're talking about. F codes are pretty common in different brands, but "32" could mean anything. All depends on what you're looking at.
Posted on Jul 23, 2010
What is a F32 error code on a maytag 3000 series
Error Code F3 E2 is a temp system error. This error is displayed if the water temperature sensor value is out of range (23°F to 217°F [-5°C to 103°C]). Correct ohm reading should be 500-100K ?.
Jan 28, 2012 | Maytag Washing Machines
WFW9200SQA12 f32 error
The "F32" error code is indicating that there is no electrical supply to the Pressure Switch from the Central Control Unit (CCU) or if the Pressure Switch contacts are not making, then "F32" is displayed.
Possible Causes/Procedures:
  • Pressure switch failure
  • Check the Pressure Switch wiring harness for continuity.
  • Check the Pressure Switch for correct operation with a Digital volt/ohm meter.
  • To manually check the function of the Pressure Switch, remove hose from switch and apply air to switch. Audible clicks will be heard from the switch.
Jan 15, 2011 | Whirlpool GHW9400 Front Load Washer
F32 error on Duet washer
f32 is pressure switch error. Disconnect the tubing and blow out the moisture and retry.
If no-go... replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 02, 2010 | Whirlpool Washing Machines
Error message f32 - not in manual
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Jan 26, 2009 | Samsung WF337AA Front Load Washer
HE Elite Smartwash quiet pac 4 front load washing machine
F32 is the pressure switch issue. Just press and hold the power switch for 5 seconds to reset this error.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine error
Hi! stachill
Sound like a power problem, or a connector problem between the three different IC control cards.
InMrFixIt
Aug 24, 2008 | Kenmore Elite HE4 Electric Dryer
F32 error code
remove bottom apnel on right side? is tech sheet with codes think f32 is pressure switch
Jul 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F32 error messaged?
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
F32 is an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works!
Waiting for your reply!
Please remember to leave a appropriate rating when you are done!
Thank You
Huuum
Jul 03, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
284 people viewed this question
Top Washing Machines Experts
