Question about Maytag Dryers
Gas Dryer Model # MGD5840TW
I purchased a gas dryer, with the above model number, but it did not have a users manuel, it was a floor model. I have looked through the listing on you site, but can not find it.
Please help
  • 60 Answers
SOURCE: Front Load LG Washer and Dryer Pedestals
If the pedestals are properly installed they pretty much become part of the washer and dryer and if those are installed correctly you will have no more vibration then if the units are sitting on the floor. If possible get the washer as close to an outside wall as possible since the floor is stronger there.
Posted on Jan 28, 2008
SOURCE: How to stack w/d gas Frigidaire Gallery dryer
You are supposed to remove the top of the washer, and the dryer feet lock into brackets...but being lazy I just bolted the dryer to the washer using some metal straps (1/16" x 8 x 4 ") with some machine screws, and it's been fine for years. Not pretty, but I had the same question and no handy internet to help me at the time ;P
Posted on Jun 26, 2008
  • 3 Answers
SOURCE: Install 220 outlet for electric dryer or trade it for gas dryer?
Thanks for all the input!  We reached a compromise in hiring an electrician who was willing to come out today and install the connection for half what everyone else quoted...on a Sunday!  The laundry piling up in the corner was very persuasive in convincing us that your advice (in the end, we'd need a professional no matter which way we went) was prudent.  Thanks. jersey p
Posted on Sep 14, 2008
SOURCE: dryer belt PH 1930 for danby model dcd5505w-1
Call Danby Customer Service at 1-800-263-2629; The part costs $25 or so plus another $7 shipping. Better than getting it through a distributor, I was given a price of $40 through a local place.
Posted on Dec 22, 2008
Controlfrk
  • 304 Answers
SOURCE: how to get into dryer to convert to LP
Disconnect power. Turn off gas.
Open the door and look along the front upper edge of the door opening. In the top left and right rounded corner of the door opening you will see screws going upward into the top. Remove both screw and raise the top.
Look down inside the open top dryer from above on each left and right edge there will be a screw holding the front assembly to the case of the dryer. Remove 1 on each side.
The dryer front can now be pulled toward you about 3 inches at the top and then lifted off the bottom clips and swung away to the right from the case. Be careful not to strain any wires connected between the case and the front.
This will expose the underside of the dryer along with motor, Gas valve and venting for checking and vacuuming. Be careful of the ignitor. It is very brittle and can be easily broken
Gas service should should be done by professionals only as improper servicing can cause fires, explosion or death from asphyxiation. TEST for leaks after reassembling gas parts.
Perform thorough vacuuming and reverse the above process for reassembly. Good Luck
Posted on Sep 11, 2009
Testimonial: "Thank you...looks like great instructions. I'll try it."
Dryer will not ignite?
gas dryer ignitor YouTube
https://www.youtube.com/results?search_query=gas+dryer+ignitor
If you go to http://www.searspartsdirect.com/ and enter your model number you can view or download you user manual , see diagrams of your dryer and order parts.
Sep 06, 2014 | Whirlpool Dryers
Need user Manuel for Kenmore gas dryer model number 97195510
Please check that model number again. It should be located in the door jamb.
Oct 17, 2012 | Dryers
My dryer is not heating when it tumbles, I have missed placed my manuel. Where can I find a replacement? Model LDG 7304 AAE purchased about 14 years ago. thank you, Patti
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 31, 2010 | Dryers
Does the maytag model number mde9700ayw have the
Yes it can be a gas dryer. If you have a electric dryer now though you can not convert to gas. If the dryer is set for propane the it can be converted to gas buy a licensed plumber or appliance repair man.
Good Luck
Apr 27, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a maytag dryer model number is mce8000ay
heatman101
Dec 23, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Jul 07, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Neptune Dryer Just Stopped
The user manual can be found here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/2206682B_MD55.PDF
The service manual can be found here: http://www.servicematters.com/maytag_library/docs/16023110.pdf
It does sound like the belt.  Refer to the service manual above on installing a new belt or troubleshooting for other issues.
Apr 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Convert Natural Gas Dryer to LP Gas
A dryer is a dryer. Most cases they all work the same. You will need to get an LP conversion kit for that model to complete the task.
Jan 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Apr 08, 2008 | Frigidaire GLGQ642A Gas Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
