Question about Pacific Digital MemoryVue MV-800 Digital Picture Frame
Memory Frame model 810
Cannot resend slideshow. Tells me to seek for update and no update comes down ?
Dis you ever get the firmware upgrade?
Posted on Jan 07, 2009
How do i get the music to play in my slideshow
what is the exact model #? Some of the pandigital 10.1" dont have provisions to play music
Feb 19, 2015 | PANDIGITAL 10.1-Inch Pan Image Digital...
Tip
Polaroid IDF-1030 Digital Picture Frame - Slideshow with Music
The manual for the Polaroid IDF-1030 is ridiculously simple and not very helpful. There's actually more information on the outside of the box.
One of the features that is not intuitively easy to figure out is how to get the frame to display a picture slideshow AND play music at the same time. The remote is the only way that you can set this up.
First, on your computer, create a folder for the images and a folder for the music. If you put music in the images folder, your slideshow will stop at the first music file it finds and just display the music player's equalizer interface. This is very boring.
Note on the pictures.. spend a little time and reduce the size of your pictures to 640 x 480 pixels. Dealing with large files on the photo frame is painfully slow.
images should be in JPEG (.jpg) format although it will also display .gif files. Music should be MPEG (.mp3) format.
Copy these folders to the root of your memory card.
Put the memory card in the Polaroid frame card slot and turn it on.
Use the remote and press the STOp button if it automatically starts displaying the pictures.
Press the MUSIC button and select the REPEAT button until you see REPEAT ALL at the bottom of the screen.
Press the PLAY/PAUSE to start the music, then immediately press the SLIDESHOW button to start the slideshow with music.
I hope this helps some of you who had trouble with this.
on Jan 07, 2009 | Polaroid IDF-1030 (826219006783) Digital...
How to start slideshow after selecting the pictures
When you power on the picture frame, a slideshow will automatically display the photos on your memory. (If you have not inserted a memory card yet, the slideshow will display the photos pre-loaded into the internal memory.)
To restart the slideshow, press
ENTER again, or press the Slide Show button on the remote control.
May 05, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
I have a smartparts picture frame.SP113mw Just loaded new pictures and first pic comes up and freezes, tried re-connecting to computer nothing. Can't use any of the buttons its locked up and can't...
The first (most obvious?) solution is to discard/destroy/disable/discombobulate the SP113MW. For my Mother-in-Law, I just deleted some of her images from built-in flash.
The SP113MW has a 128 mB flash drive that is accessible by USB, per previous suggestions. HOWEVER, the probable reason that your frame freezes on startup is that you have more than 744 images in the "Smartparts Pictures" folder on the built-in flash memory.
The SP113MW has a maximum limit of 744 images for a slideshow rotation, regardless of how much space is on the drive (that includes Built-in flash, USB, SD, or any of the drives). The default drive on startup is the built-in flash, so you may just have to delete some images to get under the 744 limit. FORGET the manufacturer's claim of "2000 images" (because it is technically correct); you can store 2000, but you'll never play a slideshow of 2000 (nor any slideshow if you have that many images). Reduce to 744 (all jpg's) and all will be well.
The other irritating thing about the SP113MW is that it does not allow the slideshow to include all drives: just one drive at a time, and that drive cannot have more than 744 images on it (or the slideshow freezes). That is why your comment about "trash" may not be a bad idea. However, mine Mother-in-Law's still works, so I accepted the limit, and it still sits on her shelf.
Sep 22, 2011 | SmartParts SPX8 Digital Picture Frame
I can't get my DP702 digital frame to save my pictures from my camera. Can you tell me how to do it ... ty
The DP702 frame only takes 14 pictures saved to the slideshow file. Install a memory card/device, then plug in the usb cable, electronic store carry it for 7 or 8 dollars. It's too bad, it doesn't come with the frame. Choose the photo you want saved, and press the save button on the remote to save the photo to the slideshow, if you press it again while you're on the same frame, I think it will delete that photo. I hope that helps.
Dec 26, 2009 | Coby DP-772 Digital Picture Frame
I'm trying to put a slideshow on my 2GB sandisk and play it on a digital frame and im not sure how to put the slideshow on the sandisk
Once the card is in a card reader attached or built-in to your computer, simply drag&drop the desired pictures to it. Depending on the make and model of your frame, you may have to create a folder to hold the pictures.
Dec 14, 2009 | SanDisk Sansa e250 MP3 Player
How to play PPT on Pandigital Electronic frame?
You cannot play a PowerPoint presentation files on the frame. However, if you add still images (JPG) and music (MP3). The frame can play it's own slideshow.
Oct 13, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Pandigital Photo Frame - Slideshow leaves out Photos?
Size limit depends on exact model. Anything over 4GB will almost certainly not work consistently with any. model 1GB or less should work with any model. None of the images should be stored in folders, and all should be jpeg format (.jpg). If any of them have been edited, they may be saved as Progressive jpeg or something similar even if the extension (.jpg) remains the same. If you resave the missing photos in as JPEG in MS Paint, it should ensure they are compatible. You may have to format the memory card and re-add the photos to make sure it will work,
Sep 20, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Slideshow on axion digital photo frame
noooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
Dec 05, 2007 | Computers & Internet
Pacific Digital MemoryVue MV-800  Digital Picture Frame Logo
215 people viewed this question
Top Pacific Digital Photography Experts
pontelemon
pontelemon
Tony
Are you a Pacific Digital Photography Expert? Answer questions, earn points and help others
