Question about Jensen VM9510 Car DVD Player
Overriding e brake video defeat
Have device hard wired to emergency brake wire in mits eclipse spyder, but, once connected and vid works, as soon as car is turned off and restarted, lose video again and can't get it back, so, was trying to find codes to override ebrake video defeat measure just to keep my car in one piece and be able to view video more than once
Sorry apparently was some miscommunication when posting my question, my unit is NOT the jensen but the dual xdvd10 and it actually DOES have an override code, a simple search on google turned it up and it worked like a champ from the get go.. SO, apologies if there was some misunderstandings, don't mean to step on any gurus toes or anything... thanks again
Posted on Oct 09, 2008
  • 1,586 Answers
There is no e-brake override code. You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Posted on Oct 08, 2008
2001 mitsubishi eclipes spyder replaced brake light bulb but still does not work
Did you check the socket and wires immediately nearby? I assume it is isolated to just one bulb. If not, check brake light switch behind pedal and fuse. Also, switch bulbs around just in case.
Jun 03, 2014 | 2001 Mitsubishi Eclipse Spyder
I have a 2002 Mit ECL V6 GT Spyder. windows, turn signals, radio and wipers quit. I took it in. They said I need a whole new computer ($1800) Please explain how this could be. The car runs fantastic....
. Check for voltage on the Orange/Black wire in the C89 connector. The C89 connector is under the left side of the dash.
2002 Mitsubishi Galant, ES 2.4L, L4, VIN G, Des 4G64, 16V, USA *
Electronic Timer Alarm Control (ETAC) Module Wiring
- Missing a power to the ETAC.
you posibly need to replace
Nov 09, 2013 | 2002 Mitsubishi Eclipse Spyder
Brake lights quit working, running lights and turn signals still work
find the brake light switch pull the plug off it and with a short whire short the plug out this will turn on the brake lights,, if not the fault is in the car wireing
Aug 08, 2010 | 2008 Mitsubishi Eclipse Spyder
How do I bypass the emergency brake on my Eclipse AVN 7000
You will have to connect the brake wire which is pink to the the ground wire.
Apr 27, 2010 | Eclipse (AVN7000) Car DVD Player
What does pink/brake wire on dvd hook up to?! Ex: -LF- spkr or red power?! what?! I have a "Farenheit TID 580" car cd/dvd player. I have all the wires hooked up except the pink/brake. Is there a wire on my...
Hi all car dvd players have a emergency brake safety feature. The pink wire is to be spliced into your emergency brake wire, or there is a code you can purchase to bypass this feature.
Thank you for using fixya.com
Feb 09, 2010 | Eclipse (AVN7000) Car DVD Player
How many courts of oil does the 01 Mits. Eclipse Spyder take?
The 1800cc takes 3.9 litres with filter
The 2000cc takes 4.4 litres with filter
Hope this helps
Jul 10, 2009 | 2001 Mitsubishi Eclipse Spyder
Emergency brake wire connection
Here's a Bypass to solve that. Turn your 9312 on and set to radio then Using your remote enter 543210 and make sure you hear a beep each time, a new menu screen will pop up, click the hammer and screwdriver on the upper left side,Next press the menu line for brake override, a sub menu will appear, select ON,Press the X at the lower left of the screen and you're done enjoy and be safe.
Apr 12, 2009 | Jensen's VM9312 Car DVD Player
Power Acoustik PTID-4007 Okay, so I checked my radio fuse, it's fine. Checked for constant and acc 12v. and they are there. fuses on harness are good. I spliced my adapter harness onto the PTID-4007...
i have Power Acoustik PTID-4007 my problem is not turn on lcd not out audio but yes is take cd and out cd, the screen is move in three postion. help me please
thanks
Mar 08, 2009 | Power Acoustik PTID-4006T Car Video Player
Jensen VM9510 Car DVD Player Logo
212 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
