Question about Garmin eTrex GPS Receiver
Wont do anything
My garmin etrex does nothing with new batteries I had the gps on all day while boating. Forgot to turn it off. Checked on it the next afternoon and screen was blank. Replaced batteries, unit will not turn on. Cleaned the already clean contacts and checked all connections with a meter. No luck. Is this unit now a paperweight? Can it be taken apart to check further?
  • lt7578 Sep 11, 2008
    My son just contacted me from college stating much the same thing. He has the eTrex. The old batteries died so he changed the batteries, turned it on to make sure it worked then turned it off. Later he tried to use it and it will not turn on. I advised him to check battery type and contacts to make sure they are still in proper positions. It may be a few days before I know if any of the above provided a solution.
The eTrex is on the way back to Garmin! I contacted Garmin ref this problem and the tech suggested that I try to 'reset the master'...Power device off (it won't turn on so this was not a problem), press and hold down for 5 seconds the following button combination: page+enter+power. If this works a prompt will come up asking if you want to clear all user data, to which you have to select 'yes' and this will erase all data saved/stored. Leave the device outside for a minimum of 20 minutes so that it may properly acquire satellites. If the device does not awake using these directions...back to Garmin, which is the action I must now take! lt7578
Posted on Sep 29, 2008
I have a garmin etrex legend c. i have only used the item a coupel times in the past 2 years. now when i try to turn it on the screen just turns black pixelated, no color or anything. new batteries were...
Try updating the unit`s software. This can be obtained for free from Garmin.com. A new satellite launched was causing reception problems and the update fixed it. This might be the problem with your unit. Come back and let us know if this fixed it.
Sep 23, 2010 | Garmin eTrex Legend GPS Receiver
Barmin ETrex Hc won't turn on
I had the same problem as you with the unit switching off.
I found this link http://www.fixya.com/support/t2084694-gps_stay
I held down the joystick button to perform a "Bootlock"
I don't know if it will work for you.
I got Garmins WebUpdater here http://www8.garmin.com/support/download_details.jsp?id=931
Feb 01, 2010 | Garmin eTrex Venture HC GPS Receiver
My Garmin eTrex Summit HC will not turn on. I
absolutely! Hve yoiu checked that this model does not have a switch on the rear as well as on the front? the one of the front is standby. The other one is main power. Not 100% sure about your model so just check first. Other than that take it back to seller for replacement or instructions
Jun 28, 2009 | Garmin eTrex Summit HC GPS Receiver
Garmin eTrex Vista Cx won't turn on
Call Garmin customer service, they are wonderful. My rubber thing around the outside became loose,and they sent me a new unit, even though it was almost 2 years old.
Apr 11, 2009 | Garmin eTrex Vista Cx GPS Receiver
Garmin etrex screen too dim to read
I have an older Garmin 12XL and suddenly the screen turned very dark. I tried replacing the batteries and let the GPS rest for a week so the internal lithium battery could re-charge. But that did not work. I just got an email from a friend who had the same problem... it turned out that his unit had changed the screen contrast setting all by its' self.
This may not be the cause of your problem but it's worth trying... go into your "Settings" menu and reset the contrast and see if that cures the problem. Good luck.
Sep 22, 2008 | Garmin eTrex GPS Receiver
My Garmin Etrex wont turn on on batteries but it works fine on external usb power.
I have the same problem. The unit works until I connect it to whatever computer via USB (Mac or PC). The screen blanks out as soon as I plug in the USB cable. I have to disconnect the device and only then I am able to turn it on again. That started after Firmware update from V 2.90 to 3.00 . I am not sure this is causing problem. What about the firmware versions of your devices ? Are they all on the latest ?
However, does anybody know if there is a way to go back to firmware version 2.9 if it is not possible anymore to connect the device to any computer (evtl. through putting data on the microSD card ?).
Thanks,
Martin
Jul 04, 2008 | Garmin eTrex Legend Cx GPS Receiver
Etrex will not turn on
If batteries were ever put in backwards, you cooked it.
Feb 11, 2008 | Garmin eTrex Legend GPS Receiver
Garmin etrex handheld
There's really nothing to setup, you just mark waypoints and it displays them on the map. If you press enter on any screen, it will give you options for that screen.
Jul 30, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex GPS Receiver Logo
188 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
