Question about Canon PowerShot S3 IS Digital Camera
Power When I put new batteries in my camera it tells me to change the batteries
  • 9 more comments
  • bmcaleer Oct 18, 2008
    When I got the message to change batteries, I put in new ones. Camera worked for a couple of minutes and then the battery icon started blinking and I got the message "change batteries".
  • Anonymous Oct 21, 2008
    Same problem, except it only says change the batteries when i turn the camera on not when i view the pics.
  • TDeGrado Nov 04, 2008
    OK, maybe not the same problem, but similar. Mine said change the batteries. I did. Used if for a couple of shots (maybe 5) and heard a "pop".
    Now it's dead. The lens is stuck out. Won't work at all. Anyone else have this issue?
  • Anonymous Dec 02, 2008
    When I got the message to change batteries, I put in new ones. Camera worked for a couple of minutes and then camera powers off and I get the message "change batteries".
  • chrispc Dec 18, 2008
    My S3 is just over 2 years old. I primarily used rechargeables with alkalines as a back up for special events/heavy shooting. This summer I was away from power for a week and took and used only alkalines. Now the camera only powers up with new batteries, and if I use flash, I can only get maybe 1 shot off before "change the batteries" message appears and lens collapses and camera finally shuts off. I've re-tried rechargeables, different memory card, reset camera, pulled date battery (3.6v still), tested voltage on multiple sets of new alkalines after "failure" (all full and over 1.5v). A call to Canon was no help nor was cleaning contacts... Sadness.
  • Anonymous Dec 30, 2008
    Same problem. Approximately 2 years after buying the camera, it displays the "change batteries" message no matter how new the batteries are. If I{m lucky, it will power up for a single shot. Batteries are not drained, and no, it does not depend on the type of batteries. I tried several types, and got the same results each time.
  • dutchaccent Feb 13, 2009
    Hi, I also cannot take pictures, or maybe one or two before my camera tells me to change the batteries. Changing the batteries doesn't help, though.
    I'm desperate!!
    Please help!
  • nherrera_ce Feb 24, 2009
    My Canon S3 IS is doing the same thing. Mine started after I left it in the car during a freeze. The temperature was around 0 degrees F or so. After that it has done this no matter how fresh or what type of battery I put in, it always says "Change Batteries" I can review old pictures though. Anyone know what part usually fails on these when they are subjected to freezing temperatures?
  • MarkQUK Apr 05, 2009
    Switching on the s3 just gives message change the batteries, no matter what I've done (new batteries, cards, reset, clean etc.) can't get it to start up for more than a few seconds. Still reviews, connects to PC etc. so not a loss of power.
    Camera is 2 years old.
  • manhie May 02, 2009
    I have the same problem. Batteries need to be replaced after a few shot. I put in new batteries. I think Canon has a defect there.
  • Anonymous May 08, 2009
    Same problem too.
It depends of the type of batteries. try alkaline or duracell heavy duty
Posted on Sep 10, 2008
I replace new battery for my nikon coolpix p600 but still can not switch on. Please tell me how to fix this problem...thanks Larry
You will have to tell us what happens when you put a EN-EL23 battery inside the camera and you hook it up to the charger or USB. If the charger or USB is hooked up the Camera will Turn ON. The POWER LED will be GREEN. Another LED on the camera will FLASH GREEN. If this happens when you charge it you are halfway home. Change it until the flashing LED turns off. This means Battery is FULLY changed. Then REMOVE the USB or CHARGER and try to turn it on.
Jan 18, 2017 | Nikon COOLPIX P6000 Digital Camera
Chime
power cycle the system then hold star and pound that is a back door into programming hit #20 that will tell you the installer code then hit *99
once you have the installer code hit (Installer Code + 5 + 0) if you want to change the master code hit installer code + 8+02+new code + new code to create a new code
May 16, 2013 | Honeywell Ademco Alarm 6150rf Keypad Lk
When the camera is powered on it says "change batteries" although i would've just put in new ones.
maybe the one you installed is not matched on your camera, means if it is alkali battery recommend by the manufacturer then use alkali battery. also set the menu you need to tell camera that you installed new battery.
Feb 02, 2011 | Canon PowerShot S2 IS Digital Camera
Put in new batteries no response wont start=changed batteries
HI there try to clean the battery compartment and and then try. After that if not work then i am sure the camera power suply transformer is damaged anmd thats why itws not able to receive power from the battery. So you need to repair your camera from the camera service center. Thanks.
Nov 29, 2010 | Pentax Optio Z10 Digital Camera
Having same no reponse on new Olympus FE-3010
Unless it's a generic problem with this model. Lens out and not moving usually means it has been damaged by a knock or has grit/sand in it. When exactly did it stop working, you must know as the lens was out, hence it was on when it stopped working.
Sep 26, 2009 | Cameras
When I put brand new batteries, it says "Change Batteries"
Use a Q-tip with alcohol to clean all the batter contacts (battery cover and inside the battery compartment), and a small hook into the compartment to pull up the contacts a little bit up. The idea is to make the batteries connect properly.
Use NiMh rechargeable batteries or Alkaline batteries, don’t use other Dry batteries, which are not designed for digital camera.
Apr 10, 2009 | Canon PowerShot S1 IS Digital Camera
I put new batteries in my camera but it says i need to change them. Why is it telling me that I need new batteries when I just put brand new ones in?
you must be using battery available at the store having the handling capacity of 250 to 300 ma what you need to use is a rechargeble battery with a capacity of 2100 and above this should definately solve your problem
Oct 15, 2008 | Cameras
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
153 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
