Washer will empty water or spin out. Agitator works fine. Model: Kenmore 110. 51250100
  • 876 Answers
Turn the washer off, pull it out and unplug it. Look at the drain hose; is it twisted or compressed? If is not then disconnect the drain hose and check it for clogs. If you do not find any, check all of your household drains, particularly the disposal. This is a very common problem. You may have a general plumbing clog some where. If you cannot find a clog and all the drains are running fine, You will need to have a service call.
The best to you and Thank You for using Fix Ya. Your rating is always appreciated.
Posted on Aug 24, 2008
Kenmore elite washer model 110 won't empty water and spin
Does it agitate? If it does not then it maybe the coupler that connects the motor to the transmission. If you hear a clicking sound. This may be your problem.
May 21, 2014 | Kenmore Oasis Agitator 4.5 cu. ft....
Kenmore Oasis washer model 110.27032600; trapped hidden water
when you tipped the washer was the drain hose still attached? and if so was the drain hose elevated? most top load washers will have an amount of leftover water in the bottom of the tub. with the drain hose off and the washer tipped towards the rear you should lose any excess water. also try to open the top of the agitator to see if there is any water trapped there. hope this helps....
Oct 18, 2009 | Kenmore Washing Machines
Washing Machine does not agitate
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool installation and maintenance PDF on how top load, direct drive washers work with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is the Whirlpool parts list for commercial top load, direct drive washers although the consumer washers are basically the same.
The problem seems to point to the Agitate Cams in the transmission that raise and lower the Agitate gear on the main transmission shaft. These are relatively inexpensive to replace.
I'd also check the splines on the main agitator shaft and the two pronged "washer" on top of it.
Oct 03, 2009 | Kenmore Washing Machines
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Jul 30, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore Model 110.26712693 stuck on agitator cycle
Your air pressure hose going to the water level switch is pinched.
Open the top control panel to access the clear plastic tube and relieve the pinched area.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Washer won't spin
pull the fab soft dispenser out and pry off the cap that sits on top of agitator looking down inside there you'll see 4 pieces called agitator directional cogs(dog ears) they are worn and need replaced
Apr 06, 2009 | Kenmore 22422 Top Load Washer
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series model no. 110.26842691
Your agitator may be fine but how is your washer behaving is it trying to perform two acctions at one time like spinning and agitating at one time the tarnmission may be locked up
Jan 21, 2008 | Kenmore 24032\24036 Top Load Washer
No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
