Question about Gaggia Titanium Espresso Machine
Steamer on gaggia titanium
When i turn the steamer on, i can hear a sound as if water vapor is building up inside the unit and the lcd screen will appear to turn purple, as if it is being contaminated with water; the steamer works, but poorly
  • Samantha Ransom Sep 08, 2008
    Machine functions as if steam is being produced however this is condensing back into water and escaping into the drip tray. Also when hot water is requested this doesn't make it to the nozzle and fills the drip tray.
    Machine only descaled a month or so ago, and a pipe cleaner up the nozzle has failed to make any difference.
  • bakewell Sep 20, 2008
    I have the same problem with my titanium. Poor steaming, water finding its way into the drip tray (and beyond) and a noise like water/steam being forced through a small hole.
    Turns out the problem is just that. within the "tap" which is inside the machine, in line with the steam wand hose, sited at the top right of the machine, there are one or more rubber o-rings which have deteriorated and are passing water. Poor build quality for such a crucial component on an expensive machine.
    I haven't fixed the problem yet but would like to share my findings as it seems common to this model.
A. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Posted on Sep 14, 2008
My Gaggia Titanium machine has a full tank of water and is full of espresso beans, but it will not pull water from the water tank to make the espresso. It grinds the coffee and then when its time for the...
Hi, It needs to be taken to a repairer. It should make two clicks, then the brew unit compresses, then it should pump water for coffee. It has issues that can not be fix by text. I live on the sunshine coast if thats any help. I do repairs. Dazza
Aug 17, 2011 | Gaggia Titanium Espresso Machine
Can't prime water circuit. Sounds that the water can't even come out to the cup.
There may be a disconnected or pinched silicone hose restricting the water flow inside the machine. The pump may also be defective even if you hear it running.
Aug 04, 2011 | Gaggia Titanium Espresso Machine
Hi, My Gaggia Titanium shows a Brew unit missing error. I have tried everything i can think of; - cleaned the inside - removed and inserted brew unit multiple times - switched machine on/off (including...
Try taking the brew unit out, and clean the area inside the machine for coffee grains before reinserting it. There's a tiny sensor for if the unit is inserted, but it can be confused if the machine gets messy inside.
Aug 18, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
Will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium only buttons that are working are the large coffee and the menu button?? Nothing else does hot water, no espresso therefore no up and down arrows for the menu button!!! I...
Had exact same problem (same two buttons worked). One of two button connection ribbons (wires) had disconnected inside the electronic box in machine. Simple was is to remove the top, open electronic box, reconnect grey ribbon (back left for me), and electronic tape onto connectors. Just did this, all worked for me.
Dec 08, 2009 | Gaggia Titanium Espresso Machine
No hot water or steam from wand.
If steam wand is not blocked then the problem is on the inside of the machine, try descaling the machine that might clear the blockage in the steam line.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
No water coming through but steamer working
Check the shower screen it might be clogged.
Aug 11, 2009 | Gaggia Baby Espresso Machine
having spoken to Gaggia uk returned the machine to them directly to get it repaired
Jul 28, 2008 | Gaggia Titanium Espresso Machine
Ventilate problem
need to go through menu to factory reset. This gets machine to ready. You now need to decalcify with a citric acid descaler, not vinegar. With the water tank filled with descaling solution go through the menu to rinse option and rinse machine. When finished rinse cycle and with remaining descaling solution push water button open side knob and rinse the steamer system with descaler.
Jul 24, 2008 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
391 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
