Insignia NS-R5100 5.1ch receiver shuts down in a few seconds and Stand-by light starts flashing.
  • wlherbort Sep 12, 2008
  • naresh2u Apr 11, 2009
    Insignia NS-R5100 5.1ch receiver goes into standy after 3-4 seconds after it is switched on
The output transistors are blown in one or more channels also the driver transistors are blown in the same channel.
you can find this problem real easy using a DVOM (digital volt ohm meter) on the continuity test(BEEP).
start be removing the amp section from the receiver and laying it on the table bench whatever no going from B-C and C-E if any beeb there junk and the driver transistors are also and there are a few resistors that are junk.
parts list
2@2sd2390 sanken get from newark and only newark/farnell
2@2sb1560 sanken get from newark and only newark/farnell
2@2sd947 from newark
4@ 2sc1841 or 2sc1845 to replace 2sc1845
4@ 2sa998 or 2sa992 to replace 2sa992
8@ .22 ohm 1/4 watt metal film resistor 1%
2@ 4.7 ohm 1/4 watt metal film resistor 1%
this is a parts list for 2 channels
only get the powertransistors (the sanken) from newark any others i have found as counterfeit and destroy stuff and dont work
i dont remember location #'s on the board but
Posted on Mar 17, 2010
NS-R5100
Probably a short in the amp that will need to be repaired.
Feb 27, 2013 | Insignia Ns-r5100 Av Digital Home Theater...
I have an Insignia NS-LCD37 was working perfectly fine, all of a sudden the TV went black, I would turn the TV on and you would get the
Most likely you have a fault in the back light circuit. To verify this, turn on the set, when the screen goes black, take a bright flashlight and shine it on the screen. It may be easier to dim the lights in the room so that you can see the faint image on the screen. If you see the faint image, you indeed have a back light problem. You will need to get a diagnoses performed on the set to track down the problem
Nov 22, 2012 | Insignia NS-LCD37 37 in. LCD TV
Insignia tv powers off and on on its own
Sounds like a main board issue, the set needs to be serviced
Aug 20, 2012 | Insignia NS-LCD37 37 in. LCD TV
Screen flashes on and off every few seconds
Sounds like you may need a new power supply. I found one at ShopJimmy.com and included a link. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/insignia-adtv24250bb1-power-supply-unit.htm
Oct 25, 2011 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Insignia GPS INSIGNIA NS-CNV20 Pover Up and Shutting down
Try resetting your navigator by inserting a tin tool (e.g. unbent paper clip) into the reset port. A schematic can be found in the owner's manual. Also, ensure that the unit is securely connected to power or that the battery is fully charged. If these steps don't resolve the problem, return with the unit to the place of purchase to pursue service options.
Mar 10, 2010 | Insignia NS-CNV20 Car GPS Receiver
Where?
power button is the little nipple between the phone and play/pause pictures on right side. You hold down for 2 seconds until blue light comes on to turn on.
Too shut off hold down button 4 until red light comes on.
if want too pair with device hold button down 6 seconds until light blinks blue red
pass code is 0000
May 15, 2009 | Insignia Bluetooth Wireless Headphones...
My mp3 GMP32000B wont conect on pc with usb
i had this same problem. mine kept shutting down after about 15 seconds and my pc didnt recongnize it. i restarted the firmware and now it works fine. search on the new for CheckUDisk.exe this will give you the chipset and search for the chipset firmware.
Oct 11, 2008 | Insignia NS-DV2G MP3 Player
NS-xV24 Insigna Pilot
1) Hold the power button (slider) in the on position for about 15-20 seconds to force the player to turn off, if it's already on.
2) Hold the menu button down and simultaneously hold the power button (slider) to the on position.
3) Do not let go when the device turns on. You will then get a screen message in black and white that reads (with a typo):
WARRING !!!
NAND FLASH MEMORY INITIALIZE......
"WARRING !!!" will appear in red (and probably should read "WARNING". You will have the options of "No" and "Yes".
4) Choose "Yes" to re-format your device.
Jun 24, 2008 | Insignia Pilot MP3 Player
1,063 people viewed this question
 Grubhead
Grubhead
