Question about Osicom NetPrint 500 Print Server
Osicom NET500E/N - Lost PassWord, How Do You Reset
I have a net500e/n print server and no longer have the password assigned. It is not sysadm. That being the case I cannot change necessary setting, ieTCPIP address. Is there any living sole out there
who would know how to RESET. I sure hate to trash/can the unit. Has
done a good job for years. Thanks
Product NETPrint
Version 500 E/N
Method Telnet
Reset the device and then try this:
User ID sysadm
Password sysadm
Level Admin
Posted on Sep 10, 2008
How to reset HP Windows server 2008 password if lost it?
Use password reset disk to reset HP Windows server 2008 lost password.
1. If you have created it, insert it into HP computer and type incorrect password when you are asked to input logon password.
And then click "Reset Password" link to begin Windows server 2008 password reset.
2. If you have not prepared it before, create one now with Windows Password Genius.
Insert password reset disk into locked Windows server 2008, and boot HP server from reset disk. Choose account and click "Reset Password".
Sep 06, 2013 | Microsoft Windows Server 2008 R2 Standard...
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
on Oct 19, 2010 | Computers & Internet
I have instatalled a DP 301 print server for my HP 2300n printer. I am not able to get nbtstat reply from this device. IP for print server is manually configure. ANy help?
Yes. In most cases you can reset your D-link DP-300 series or DP-301 series print server yourself even if you don't know the password or IP. This comes in handy in situations such as when the server has made up its own password after being connected to a new router.
Cross your fingers and try the following steps...
1) Install the psadmin software if you have not already. If you have lost the psadmin software then search for it on the web.
2) Start the psadmin software and click "factory reset".
3) If the software demands a password, try "SYSxxxx", where xxxx stands for the last four digits of the MAC address located on the underside of your server. (Example: if your MAC address were "63 XE 29 44 F2 96", then your password would be SYSF296.)
4) Click yes to confirm the reset.
5) Follow the non-intuitive instructions provided with your server to set it up again. (Note that a Quick Install Guide will likely be more useful than a manual for this step. If you have lost your Quick Install Guide then try downloading it from D-link's website, http:/ Locate your model via "product quick find" or "find your product" then click on "support resources" and look for a quick installation guide.)
Shahzad IT Department Mitsubishi Motors KSA
Dec 17, 2009 | D-Link DP 301P (DP-301P) Print Server
Can't reset password D-link DP-300U
Can anyone tell me, what IP Address when reset to default? thx's...
Sep 05, 2009 | D-Link DP 300U (DP-300U) Print Server
Hi , please i have forgot my password Dlink dp 300u ,can you help me please?
Try using the psadmin software to do a factory reset. If it demands a password to do this, try using "SYSxxxx" (where xxxx stands for the last four digits of the MAC address written on the underside of the server. If you don't have the psadmin software you may be able to download it off the internet. After doing the reset you will need to follow the Quick Install Guide to set up the server. If you lost the Quick Install Guide you can download a new one from D-link's website. The following link may also be helpful:
Apr 20, 2009 | D-Link DP-300U (DHDP300U) Print Server
How to reset Admin password D-Link print server DP-301P+
Unfortunately the D-Link Print Servers are secure and cannot be reset without the password. The unit will have to be sent to D-Link to be reset.
Apr 17, 2009 | D-Link DP 300 (DP-300) Print Server
Oce tcs 500; system administrator passwork
I am guessing this is a Windows XP system that it is connected to. Reboot the computer and as it is booting press the F8 key. It should bring up a menu for boot options. Select Safe Mode and at the log in screen select Administrator with no password. In a lot of cases this will get you in so you can go to the control panel and remove or reset the password.
If that doesn't work you can also search on google for XP Administrator Password Reset CD.
Jan 03, 2009 | Office Equipment & Supplies
Osicom ROUTERmate T1 Drop and Insert CSU/DSU (RM-T1/D1/R)
Aw man your in a pickle here. I used to know a man named Mike Sandman when I worked in Chicago goto his website If anybody knows how to reset or hack the managment pass its him. I'm telling you as far as Telecommunications stuff goes Mike is like Leonardo Da Vinci
May 02, 2008 | Osicom ROUTERmate DI (RMATE-T1/DI/R)
Cant change or remove the password.
with some system you will have to use ctlr H before the password system
this removes the space so the password is correct
Aug 03, 2007 | Emulex NETQue Print Server
Osicom NetPrint 500 Print Server Logo
189 people viewed this question
Top Osicom Computers & Internet Experts
David Payne
David Payne
Are you an Osicom Computer and Internet Expert? Answer questions, earn points and help others
