Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Water dispenser I have a kenmore side by side refridgerator, the water started leaking constantly the only way to stop it is I had to turn off the water supply. Any ideal what I could do to stop this.
I HAVE THE SAME PROBLEM WITH THE WATER CONSTANTLY DRIPPING FROM THE DISPENSER, I REPLACED THE HOSE AND THAT DIDN'T DO IT. ANY SOLUTIONS?
Posted on Sep 01, 2008
My Kenmore side by side fridge #596.55669500 is leaking through the water outlet in the door. Not constantly but often enough to be a problem. What could cause this and is it something I can repair myself?
If its dripping water mostly after using Changing the water solenoid in the back will fix the problem, Thats the blue valve on the back that is connected to the water supply line.
If its turning on intermittently and dispensing water you may have to replace the control board for the dispenser.
Its either hard water causing the fill valve(Solenoid) to not close all the way or an electrical current opening the valve .
May 22, 2011 | Kenmore Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Jan 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Kenmore 57033 Water Dispenser Broken
I had a similar problem on a frigidaire side by side. I think the water line may be freezing. My solution was to remove the filter inside the refridgerator and drain it and reinstall. This causes the water to flow into the filter and eliminates any ice in the tubing. I have not had the problem in a while. While not a true fix, it may help narrow it down.
Later on, I eventually replaced the microswitch on the door dispenser for an intermittent dispenser problem.
Hope this helps.
Dec 28, 2008 | Kenmore 57029 Side by Side Refrigerator
Kenmore refridgerator mo. #58251890,water dispenser will not stop
sounds like the switches are getting stuck and not releasing properly. the switches are inexpensive and relatively easy to replace if you want to tackle the problem yourself. Joe
Nov 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Leaking water
turn the water off its behind the unit on the wall .
you might have a busted pip in the door but only tech' can fix that ....
Aug 30, 2008 | Kenmore 53082 / 53084 Side by Side...
Kenmore no water
does the machine have a lock out button on the despenser that you can push to activate the water and ice
Apr 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
181 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
