Question about Apple iMac G4 Desktop
IMac I purchased two 256mb modules because I was told by the seller that this would increase memory to a total of 512mb. (I'm starting to have my doubts about this!) I installed the first chip without any problem. The computer started up and ran well.  As was explained by the seller, the second chip was located underneath the processor. I installed the new chip (again a 256mb) and carefully replaced the processor. Now my computer will not compete the start up process. There is an initial starting sound, the orange light comes on, and that's where it stays. The green light on the start button does not appear. Have I damaged the processor in removal? I've double-checked all connections and they are solid. Is there some form of fuse in this system? HELP!
  • wolfandbunny Aug 24, 2008
    I should have added in my original note that I had removed the 256 module and replaced it with the original that came with the machine, hoping that would at least solve the problem.
    Well.....it didn't.
    O.K., I should have added to the original statement above that I did switch the new 256 module out (located under the processor) and replace it with the original chip that came with the machine.
    There was no change in the start-up problem.
    Master:
  • 521 Answers
There is no something like fuses in the board.your chip and processor both are ok dont worry about that.just remove the chips and processor.and get it checked from where you have got the chip.as many times this happens when we insert the new chip this problem occurs.for a period of time.and then it disappears.just get it checked.as the chips and the processor are not that sensetive to be damaged in simple fixing.check all the standing copper pins.are they proper.thanks.rate the solution.
Posted on Aug 24, 2008
    Genius:
  • 2,028 Answers
This sounds like a problem with the second memory chip. Remove it, and see if the machine starts correctly. If so, then put the first chip in under the processor, and try the startup. If it starts, then put the second chip in. If it doesn't start, then I'm going to say that you got a bad chip. It's not that uncommon to get a bad chip straight out of the box. I seem to get about one in every forty, here at my shop.
  • Ryan Rogers
    Ryan Rogers Aug 24, 2008
    Can you get to the bios?
  • Apple Master
  • 13,433 Answers
There are no fuses. try removeing the one of the memorys and then both. insert the old memory and see if it starts up.
let me know how it goes.
  • 1 more comment
  • Ekse Aug 24, 2008
    Remove and test, then remove another and test yes without memory at all, put the old back in. should start up. take the old out. put both new in.
  • Ekse Aug 24, 2008
    remove the new chips, start up without any memory, then insert the old memory. see if it starts up.
  • Ekse Aug 24, 2008
    did you take all the memory out and try starting up without any memory? after the startup has failed without any memory insert the old one only.
Have dell 600 with 256 memory cardx2 if changeone to 512to 767 total will it increase speed
768MegaBytes.
768MB
Yes is the answer
Blinding increase in speed that you will phone home, and all your friends?
NO
But an increase in speed nevertheless.
For additional questions please post in a Comment.
Regards,
joecoolvette
[Oh,...and put the 512MB Ram Memory module ('Stick'), in ram memory Slot 1. Also known as DIMM 1.
256MB in Slot 2.
The Processor (CPU) reads what is in Slot 1 F-I-R-S-T ]
Feb 16, 2013 | Computers & Internet
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
Poweredge 700 will not recognized memory
Unless only one 256-MB memory module is installed, the modules must be installed in identical pairs. If you want 512MB total, you will need to populate by using two identical 256MB modules or use the same technique for larger memory sticks. That model supports up to 4GB ram of the following type;
PC3200 ECC DDR SDRAM DIMMs
May 21, 2012 | Dell PowerEdge 700 Server
Have 512MB RAM. Was told to max it out because the machine is extremely slow. Has two slots with 256MB. Can I put two 512MB memory modules in those slot to increase 1G or RAM?
yes, after looking up your laptop on hp's website, I have determined the kind of memory you need; (assuming your computer is the one you put in the question, HP Pavilion ze4805us Notebook PC)
you need 2x 512 mb, 200-pin, DDR 266 memory
I looked and found some Corsair (highly respected company in computer memory) memory, for 22.99 for each DIMM (you'll need to buy 2); see link below.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145482&cm_re=ddr_sdram-_-20-145-482-_-Product
If you have any more questions, please let me know!
Thanks,
Mike
May 16, 2010 | HP Pavilion Ze4805us Notebook
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
If I unstall DDR400 memory as as follows: DDR1 & DDR3 : 512MB each DDR2 & DDR4 : 256MB each making 1.5 GB in total, will dual channel technology be activated?
Definitely not. Dual channel technology requires that the 2 RAM modules installed in each bank be of the same capacity, data rate, & even better be from the same manufacturer.
Oct 30, 2009 | Gigabyte GA-8I915G Pro Motherboard
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Sharp Actius AV18 does not recognize added 512MB PC2700 RAM. The machine still only sees 256MB. Is there something else I need to do?
I assume the laptop had originally 256Mb RAM and you put 512Mb RAM in a the spare memory slot and you expected to see 768Mb of memory, is this correct? Try removing the 256Mb memory module and insert the 512Mb memory module and see if the laptop boots up with 512Mb of RAM. If it doesn't boot up then the RAM is either incompatible or faulty. Try using RAM modules from the same manufacturer.
Jun 09, 2009 | Sharp Actius AV18 Notebook
Acer Travelmate 529atxv states max memory as 512mb
512mb is the max memory amount this computer will accept.
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot. Two slots total. Hope this helps.
Mar 07, 2009 | Acer TravelMate 529ATX Notebook
Would like to upgrade the memory. find out exactly what type of memory is in my computer. Model 5000 5400 US Serial No. 2H21KKLK21VG Purchased April 2002
Your computer model takes133MHz Synchronized DRAM. this is different from Asynchronized DRAM. Its very important to purchase the one versus the other.
I recommend Corsair.com for getting memory modules.They make the Micron Brand to meet MILSPEC for the US Govt and Military. Corsair memory comes with a lifetime warranty and I rarely have to have their memory replaced but when doing so, there is a no questions asked policy.
They also have a memory configurator, where you type in the make and mode of your computer and the program prompts you for the memory to purchase.
Please note: You can only increase your memory installed to 512MB, using two 256MB modules. 512MB is a minimum for Windows XP and probably won't run Vista should you want to go down that route. I'd suggest buying a used copy of Windows 2000 for an EBay Power Seller with a strong rating. Windows2000 is virtually WindowsXP but its needs for Memory are quite a bit smaller and you'll have a better experience.
Regards,
Worldvet
Aug 06, 2008 | Compaq Computers & Internet
Apple iMac G4 Desktop Logo
76 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
