Question about Electrolux Freezers
Electrolux freezer ffo723dw5 will not freeze
Freezer only hume's( elect) but will not start compressor.
    Master:
  • 623 Answers
Some -possible-faults
- low voltage ( extension cord, not on a dedicated line )
- compressor drawing too much current
- bad start relay/overload
- poor air flow ( plugged condensor coils, bad condensor fan motor - if used )
- bad compressor
Posted on Aug 24, 2008
    Master:
  • 521 Answers
Check the fan motor.
  • 2 more comments
  • tech expert12 Aug 24, 2008
    which supports the compressor.
    if the fan motor is not working.replace the motor.
    it the motor is working then the problem is with compressor.get it repaired or replaced.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
The freezer stopped working and it does not freeze
check power supply , thermostat or the compressor
Apr 13, 2011 | Electrolux Freezers
Electrolux freezer ffu14fc6cw0 will not cycle compressor
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
My upright freezer temperature won't go below 20 degrees and won't freeze bread
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 26, 2010 | Electrolux Upright Freezer EILFU17GS
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
My kelvinator upright freezer stopped freezing and it just kicks on and kicks right back of what could be wrong with it?
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
May 20, 2010 | GE 13.7 cu. ft. General Electric Upright...
Hi there. I have Electrolux freezer EUU 6174. The problem is that the compressor is switching on and off for 5 seconds and the temperature is to hight. I can't store any food in the freezer. can u help me?
your problem is likely the starting capacitor .. that is a metalic part (about the size of a fist) that is mounted on the compressor or near it .. it will have wires going to the compressor .. the capacitors are not very expensive and usually easy to change but make sure the unit is unplugged .. you can either write the numbers down off the capacitor or remove it and take it with you to a parts place to get a match ... take a photo or draw a diagram so you know where the wires go .(they usually just plug in) . .. you can order one from electrolux (might be higher price) .. dont allow the unit to continue running with the bad starting cap since the compressor can be damaged eventually ... if you call a repairman .. then make sure you tell him its a bad starting cap so he can bring one wiith him and avoild a second trip .. give him the model number and numbers off the capacitor if you can ... often the capacitor is actually two capacitors in one can ... one is for the compressor and the other is hooked up to the fan ... in that case replacing one would also replace the other ..
Dec 23, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
Freezers Logo
136 people viewed this question
Top Electrolux Freezers Experts
AJMAL KHAN
Dennis Boxerman
Fred Sops
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
