Question about Kitchen Ranges
Frigidaire stove oven will not heat up. upper element gets warm then shuts off, comes back on then shuts off. the bottom element tested fine but is only getting 48 volts
  • 639 Answers
Hi csnzt,
Happy to help you!
If it is 10 years older or more, I would not recommend investing a lot of money into repair!
I think that this problem will be solved only by service!
Try these guys first!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 25, 2008
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
The oven on my Frigidaire FEF380MXDCB just stopped working. It is about 4 years old. It was fine yesterday. Neither the upper nor lower element will heat. Clock and stove elements work fine. I'd had...
It is most probably the oven temperature probe need to be replaced. Its only a plug and two screws on the back of the oven.
Go to the appliance parts pros web site, the part is $23 and they have a video. http://www.appliancepartspros.com/repair-help/frigidaire-range-fef380mxdcb-repair/fef380mxdcb-wont-start.html
Oct 24, 2017 | Ovens
Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Feb 27, 2010 | Ovens
Need heating element for oven of 1950's Frigidaire by GM stove
Fixya is unable to identify parts sources.
Jan 23, 2018 | Ovens
Oven does not work- broiler does
You have a heating element out in the unit. This element is located in the bottom of the unit. Unplug the stove and take out all the racks. There should be one screw on each side of the element on the back of the stove (inside of the unit) take out the screw on eack side and GENTLY pull on the element and you will see wires conected to the element. Dosconet and replace the element. You might see that one wire is burnt and not conected. You might try reconcting the wire and testing the unit. If that is not the case then replace the lower element and problem solved. If you have any more questions feel free to ask and I will be happy to help. Good Luck.
Aug 24, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Feb 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Fef369cgsd frigidaire oven
What do you mean by, "properly"?
Is it heating or not at all?
Is it not hot enough, or too hot?
Upper element is for broil. It may come on briefly during bake, but usually at half power. It doesn't glow red.
Does the bottom element glow red? If not, inspect lower element, which is the bake element, for pits and rough spots. These may be signs of failure.
UNPLUG STOVE!! Remove bake element and check for continuity. If it shows open, replace. You can probably take to parts store and they can test it for you.
Nov 20, 2007 | Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
