Question about Dryers
Hotpoint condenser dryer ctdoo
Have a hotpoint condenser dryer and the water is not condensing
  • 51 Answers
Water pump at the back of the machine at the right hand bottom corner has either been blocked up with gunge which can me easily cleaned or the pump is not pumping, replace the pump
Posted on Feb 02, 2010
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
Feb 05, 2013 | Hotpoint Dryers
I have a Hotpoint CTD00 Condensing tumble dryer. The pump which takes the condensate to the reservoir seems to be running continually and not relying on the float switch. I assume the pump should only...
No, the float switch activates when the storage tank is full. To confirm this lift the float and you will see the "Empty Water" light come on at the front of the machine.
Jan 15, 2011 | Hotpoint Dryers
I have a new (1 month old) Hotpoint Condenser Dryer (TCD980G). When it is on the drying cycle it runs for about 30 minutes and then trips the RCD circuit. I have cleaned the condenser filter and the water...
There should be no condensation present if it is a condenser dryer, this is the idea of it.
As for tripping the electrice, then it suggests to me that the steam could be the cause of the problem.
As it is a new dryer, then I would strongly advise you ring Hotpoint service, or ring the help line number in your instruction book.
You can contact them at the following address if needed.
WWW.HOTPOINTSERVICE.CO.UK
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
How do i clean the condenser on my hotpoint tdc32?
Remove condenser, and flush it out under a running tap, or hose pipe with cold water, this will flush all the fluff out of the condenser
Please rate my solution.
Thanks.
Aug 07, 2009 | Hotpoint TDC32 Electric Dryer
My condenser tray is not filling up with water but the dryer is still working. where is ther water going and why do my clothes smell ?
I have the same problem, my water is gathering behind the condenser unit but it's stopped drying the clothes aargh!!
Jul 12, 2009 | Hotpoint TDC32 Electric Dryer
Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Jan 12, 2009 | Hotpoint TDC32 Electric Dryer
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Plz rate my solution.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Dryers Logo
258 people viewed this question
Top Dryers Experts
