Question about E-Machines eMachines Desktop PC
T6534 boot issue.
Computer Will power up and go through the CD/Rom checks, usually activates the Keyboard but only will boot from a Boot disk about 1 out of 10 times (Ultimate boot disk). No USB's or network adapters active but Monitor works when it does boot. Occasionally Boots to Bios on it's own
When I did get to boot the device manager tells me a whole section is listed as having no Software installed. I cannot remember exactly what section it was, but it was stuff like PCI bus. About 7 things all together, this was bought used with no OS and was using my XP HD from my other comp.
When I got the boot disk working I actually got it to boot from the HD (where I say the device manager) but mostly get a Blue screen error asking me to check for a Bios upgrade and shut down things like Bios shading or chacheing befor trying again.
This was bought used and advertised as tested with a minor glitch (Ctrl-Alt-Delete was said to not register, but it apparently does but hard to be sure with no boot up) so I am wondering if I should be raising hell about a bad MB or is this a botched upgrade to Vista that corrupted Bios?
AMD 3700 processor, cannot find MB model.
    Problem Solver:
  • 11 Answers
Without testing for myself, It sounds like a hardware compatibility issue. Cant say for sure without more info. Try all the components, one at a time, in another PC if you have the capability. Mainly the HDD, CPU , and memory. I have had this happen in the past. For no reason at all the components wont work together. Put them with other components in another PC and they work fine. Cant explain it, but it happens. Not as much as it used too though. Dont expect it would have anything to do with vista, except bad hardware trying to load the OS. If it were Vista, it would at least boot, in some form, even if it went to BSOD. The OS would not corrupt the BIOS. But a bad flash would, (or even a Virus). If you can, Try flashing the bios to the origional version. With the varied problems your having, I'd start there.
Posted on Aug 25, 2008
I get a blue screen on my compaq presario what could it be
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jun 28, 2011 | Compaq Presario 5000 PC Desktop
Recovery Issues A105-s361. Boot sequence always starts with HDD. Tried F12, tried F2 (bios). Any other way to boot from recovery disk(CD-ROM)!!
There is still a way for you to boot from your CD ROM. Just access or go to BIOS again, look for "BOOT" tab and then set the boot sequence of your computer and the set the first priority to be on the (ODD or CD DVD ROM), just make sure you put the CD ROM option at the first section and to do that, Use the arrow keys on your keyboard and highlight it and then press normally "F5 and F6" further instruction are there any way. Once your done, press F10 and select save and exit, Insert the disc on the CD ROM restart your computer at that time your computer should be booting now from the CD ROM.
Cheers . . .
Feb 09, 2011 | Toshiba Satellite A105 Notebook
Blue screen problem in my computer.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system. Also this error comes when there is bed indexing unit in hard drive. You can solve this errors with following 2 methods. (1)When you power up the computer press F8 key then enter in safe mode. Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error. (2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk. Boot your computer with that disk For that when you power up the computer press F1 or F2 "del" key to enter in bios. Then go to boot menu and set first boot device as your cd or dvd rom. Then save settings and exit bios. Insert windows disk in cd /dvd rom. Then it boot with that disk.Then you get this message "Press any key to boot from cd.." Then press any key. Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r" Then type "y" Then it fix error on hard drive. Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows. Thanks for using FixYa.
Nov 11, 2010 | HP Officejet 5610 All-In-One InkJet...
How to boot to CDROM? unit: IBM Intel Pentium 4 1.8 ghz
At power on, you should have an option to hit F12 or another key for boot options. From there choose CD/ROM
Aug 08, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
I want to reformat my computer, my question was how to first boot my cd rom to install...
Start your computer.
When you see the 'Press DEL to enter BIOS SETUP mode", press the 'DEL' key.
Change the "boot-order" to put your CD-ROM as the "first" (highest-priority) boot-device.
Save-and-exit from BIOS setup.
Insert the disk into the CD-ROM.
Your computer should boot from the disk in the CD-ROM.
Apr 07, 2010 | EliteGroup P4VMM2 V7.3 (P4VMM273)...
My computer keep on re-booting
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then press any key.
Then type "y"
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windwos " then it repairs old windows then it loads again old windows.
Jan 06, 2010 | Personal COMPUTER - LENOVO THINKCENTRE A61...
My computer fell and when I turned it back on it's saying check cable connection..! PXE-E63: Error while initializing the NIC pxe-m0f:Exiting Intel pxe rom no bootable device
Usually, your computer tries to "boot" from multiple sources:
1. 3.5" diskette drive, if installed, functional, and a boot-diskette is inserted
2. CD-ROM drive, if installed, functional, and a boot-CD (such as the Windows XP CD-ROM) is inserted
3. disk-drive, if installed, functional, and the "boot" record can be read from the disk-drive
4. from the Ethernet network, via a "networked boot server"
So, "check cable" means that either no Ethernet cable is connected to the computer, or that the "networked boot server" is not installed, or the boot-server did not reply.
What this means is that your disk-drive was damaged by the fall, and the "boot" information cannot be read from the disk-drive.
So, you need to replace the disk-drive.
Nov 09, 2009 | Acer Aspire One PC Notebook
I have an old Presario 5000 series PC, hard disk crashed, bought a new hard disk and tried to use the Quick Restore CD's to Restore to Factory settings. Can't seem to boot up from Disc 1 of the Quick...
For boot from disk first you have to set first boot device option in BIOS.
for that when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot menu then set first boot device as your cd/dvd rom.
then save settings then insert recovery diks in rom then check.
Then it boot from disk if your disk and cd.dvd rom works fine.
Let me know if you need more assistance.
Thanks.
Nov 05, 2009 | Compaq Presario 5000 PC Desktop
Replacing with harddrive 40GB
Did you simply swap hard drives? "Couldn't find NTLDR" basically means the PC cannot find any version of Windows installed because the boot file is missing. This could be because you have a CD in the drive or the hard drive is missing or broken.
If you put in a new hard drive to replace your older smaller one you need to reinstall Windows on that new 40GB drive or it just won't work. If you have some PC Tech friends they should be able to move the data which is tricky or help you out.
Mar 18, 2009 | Compaq Presario 5000 PC Desktop
E-Machines eMachines Desktop PC Logo
103 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
