Question about HP PSC 1350v All-In-One InkJet Printer
HP PSC 1350
CHECK PAPER AND PRINT CARTIAGE IN BLINKING ORANGE. GREEN E IN WINDOW THAT SAYS COPY
  • gingerphin Dec 10, 2008
    I don't want to print, I just want to scan. How can I make the error go away! I hate this printer!
  • roseak24 Feb 16, 2009
    I'm trying to install new ink & its still reading error ink cartridge and blinking! What do you do?
  • 535 Answers
Ur printer cardige has been short u need to replace it
Posted on Sep 03, 2008
What does it mean when a letter e blinks and the printer does not print on a hp psc 1410?
E = Error - IE: paper jam, etc... reset & restart and check errors message on computer
Mar 17, 2011 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 Windows Vista Support
I would check the HP forums as a more likely place to find an answer to this question...check here
May 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
Red light ink cartridge keeps on blinking
what does it say next to the blinking light for example check paper, check ink cartridge, etc.?
tom
Dec 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
Hp psc 1350 -check cartridge
Power off switch for a 5 minute .
It doesn't work try to reinstall the printer driver
Or check whether the printer cartridge is fit well in the printer
May 16, 2008 | HP PSC 1350v All-In-One InkJet Printer
Printer problems
try printing test page by holding down the orange cancel button & color button in copy section then letting go.
May 13, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP psc check print cartridge light is flashing
The "E" means a cartridge problem.
Have you recently changed them?
If so, did yo use "refills" or another non-HP cartridges?
Jan 11, 2008 | HP PSC 1350 All-In-One Thermal Printer
Hp 1350 all-in-one
When power is applied to the all-in-one for the first time, the power light is solid and the check paper, check print cartridge, black copy, and color copy lights flash, the display will be blank, and the all-in-one will not respond. One or more of the following symptoms will also be observed: The all-in-one keeps turning off Cannot print, scan, or copy The print carriage will not move Windows plug and play (device detection) does not occur The all-in-one does not respond when buttons are pressed, including the power button. SOLUTION: This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one. The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem: Disconnect the power cord. Lift the scanner lid and carefully line up and install the front panel overlay. Plug the power cord in. The print cartridge access door must be closed before the all-in-one is plugged in for the first time. The all-in-one cannot complete its first initialization until the door is closed. Follow the steps below to correct the problem: Disconnect the power cord. Locate and close the print cartridge access door. CAUSE: The all-in-one initializes when it is plugged in for the first time. While initializing, the all-in-one scans a bar code on the under side of the front panel cover requiring that the front panel cover be in place and that the scanner be operable. The scanner cannot operate when the cartridge access door is open On light (green) - On Check Paper light (amber) - Blink Simultaneously Check Print Cartridge light (amber) - Blink Simultaneously Black copy area backlight (green)- Blink Simultaneously Color copy area backlight (green) - Blink Simultaneously Issue Front panel overlay is not attached at all or not attached properly Solution Turn Off the all-in-one. Attach front panel overlay as instructed on Setup Poster. Turn On the all-in-one.
Sep 06, 2007 | HP PSC 1350 All-In-One Thermal Printer
Hp psc 1410v
Could be a number of things. I would try looking in printer settings first. Click on your printer, go to properties and check all settings, it may be set to do this or similar. If no go, try uninstalling and reinstalling it, or just turning it off and unplugging, replugging and turn on again can often reset irregulariites. Also try resetting default printer settings too.
Apr 07, 2007 | HP PSC 1410v All-in-One Printer
HP PSC 1350v All-In-One InkJet Printer Logo
91 people viewed this question
Ben Johnson
