Question about Philips FWC399 CD Shelf System
Cut off :|
Every now and then my C399 philips would cut off on me. It happens when I put it onto AUX (mainly thats all I use so I dont know if it does it for the others). I dont normally have it that loud but It could trip at the start or after a while and happens every now and then. I think theres something faulty inside but dont know. Once I try to turn it back on again after it trips it just trips and trips until he doesnt come back on.
Any ideas on this?
  • 5 more comments
  • LARISSA31 Oct 01, 2008
    SAME PROBLEM . COMES ON HIT CD BUTTON OR TUNER,TAPE AUX AND SHUTS OFF AND GOES TO ECO POWER. UNPLUGGED AND TURN BACK ON SAME RESULTS.
  • Joky J Oct 27, 2008
    Have the same problem. It played for about a good 10 mins. and cut off and after that it powered up, then cut off. The only thing it dose is stays on ECO Power.
  • Anonymous Nov 21, 2008
    same prob
  • djsleas Nov 23, 2008
    eco power is on can not get my stero on
  • mike234i Jan 02, 2009
    i have the same problem but i can't even turn mine back on it just stays on eco power
  • DGSS Jan 28, 2009
    Same problem
    email dgsystemsltd@gmail.com if youve gotta fix please
  • Anonymous Apr 29, 2009
    eco power stays on every time i touch a button
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
Its a safty feature when system gets too hot. allow too cool.
Posted on Nov 02, 2012
Same eyaaaaaaaaaaaaaaaaaaaaaaaaa
Posted on Oct 09, 2008
How do i fix my bolt cutters
you can try tightening all the pivot bolts but generally when this happens there is not much that can be done but to junk them
the secret with bolt cutters is to get the size that is 3 times the size of any bolt you intend to cut as cutting a maximum size bolt on smaller cutters is what puts them out of line
Jun 15, 2016 | Air Tools & Compressors
Aux fan not cutting in when o/heating 1989 190E 2.6Ltr. Fans operate when tested.
Your vehicle should have a viscous fan clutch for controlling the engine temp from overheating. The auxillary fans in front are used when the a/c is on. I would start by spinning the engine fan or viscous fan by hand when the vehicle is off. The fan should show resistance when you spin it. If it doesn't and it just free spins then the viscous fan clutch is bad. Let me know what happens when you spin the engine fan and also exactly how high does the engine temp get. Does it reach the red mark?
Feb 23, 2012 | Mercedes-Benz 190-Class Cars & Trucks
I got problem in my cellphone when i open to slide it its hang and i cant see the number or message something i dont know? this is my unit my cellphone.w395
It is possible that your display gets cut off fromthe main board becasue there is a flexible strip connecting cord that would have got cut and disconnected the display . This happens becasue of the slide action and a fault that comes with long use. The stip wries needs to be changed which you need to do it at a serrvice replair shop. Hope this works as thought. Good day.
Jul 26, 2010 | Sony Ericsson w580i Cellular Phone
If main water supply line is shut off and thermostat is turned up on my gas water heater could relief valve open ?my girlfriend was taking a bath and told me the water pressure was weakening and water...
pressure would go down any time the water is cut off. Temp went down no make up water relief went off cause you turned it up. put it back and put the main back on.
May 09, 2010 | Water Heaters
My Dual amp wont put out power when deck is in aux or ipod modes.
my pioneer deck does the same thing its just that when in aux mode, it will not play loud enough, i have to turn it up all the way just to hear a little sound, and i really dont know y, but when in those mods, it usually doesnt put out sound on ur subwoofer or amp rca wired on back of ur deck, and usually they do, but the power is not large enough for ur amp to pick the frequency up from ur rca wire connections. that also has happened to me before, i just usually ignore it, and just burn an mp3 cd w like hundred songs, so i dont need a ipod or mp3 player for aux.
hope i was help :)
Aug 14, 2009 | Alpine Car Audio & Video
Old plastic ignition switch caught fire,have to replace wires rt
supply to switch,switched supply ,and starter motor ,with the posibility of an aux for teh radio
Aug 12, 2009 | 1993 Isuzu Rodeo
My DGB-500 Cuisinart Grind & Brew coffee maker leaks coffee
I found out that internally the water line that comes off of the heating element is made of a rubber/silicon material. The heating element is so hot that it scorches or dryrots the tube and it cracks causeing leaking. Sometimes it comes pouring out and other times it just is enough to make it a pain. I have taken the time to get my specialized screwdriver set and take off the bottom of the pot, but have not been able to find a replacement tube for it. (They also made the tube so that you dont have enough to cut the broken end off and put it back on and if you COULD do it, they also put an "X" in the original tube so if you cut it and try to put it on you cannot push it on far enough. Other than this, it was a great coffee brewer for me for the past four years. (Put baking soda and water paste on the coffee stain if you have formica counters. A few times of doing that and the stain will come clean)
Apr 11, 2009 | Cuisinart DCC-1200 Coffee Maker
Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Jan 28, 2009 | Philips HTS-3565 Theater System
Can't load video on my 8 gb gogear
hi , first of all , you need your cd to install your converter programme let me know yvon chow !!!
Dec 30, 2008 | Philips GoGear HDD1830 MP3 Player
My 42 inch plasma wont turn back on after power cut?
We purchased a phillips plasma 50" in july 06 and it cut on and off 5 or more times a day I called phillips customer service they told us it was due to the cable company they came out and changed the tv jack gave us a new box and tested the lines said everything was ok. The problem still kept happening got back to phillips and they sent us a flash drive to update the info in the tv. still kept happening told us it was due to tv being sensitive to power flutuations. well we are now 5mths out of warrenty and the power board blows up! phillips will not do anything to help the person I spoke with admitted we were given bad advice the bill was estimated at over $500 so if I were you if its still under warrenty make them send someone out to look at it, Reading up on phillips tv complaints this seems to be a common thing By the way phillips customer service sucks dont rely on them to help you much. good luck
Jul 02, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Philips FWC399 CD Shelf System Logo
604 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
